That stuff doesn't matter. Makes zero difference if you use cruise control or not. Doesn't even matter if you floor it off the show room floor a million times on your way home.
Rings seat within minutes of running, think of how many times they move up and down in that small time frame. Even take built engines for that matter, they are built and put on the dyno and immediately put to work.
On 10/20/2021 at 8:52 AM, BeardedHunter said:
Newbie here... just dumped a disappointing 2021 EcoBoost for a 2022 2500 Z71 Sport 6.6 gas. I'm due to pick it up in 2 weeks. MPGs I'm seeing posted are impressive. I've got a 30ft TT at 7k lbs, guessing the MPG will be between 8-10 based on what I've read.
I've got a 30 foot TT, you're right on with mileage while towing.  Mine generally gets 11-13 when not towing, but I really don't drive on the highway much.  Plus I have 20x10's and 35's which doesn't help
I have a 2020 Silverado 3500 with 6.6 gas. Empty I get 19 to 20 MPG. I drive 65 to 75 mph.  I've pulled several loads of lambs grossing over 26000 lbs. Get 7.9 loaded and around  9.5 to 10 with empty trailer. I run E-25 when I can get it, about half the time. The thing on the dash says best mileage is 26.6. I have about 18k on it.
How does your truck handle that load?  How does it do on the hills?  What gear are you in at highway speeds?  What RPMs do you see?  Are you satisfied with your truck, specifically the drivetrain?
Thanks in advance!
Thanks in advance!
Handles load good,  cruising along on flat rpm under 2k, first down shift 2300 next down around 3000. Shifts are smooth. That is in tow mode. Never drove a diesel much, but what I have this will get there quicker.but I don't pull  30000 gvw loads. Most of my miles are pulling something. Even if it's a 4 wheeler trailer.
I took my 275/65/20 0ff and put on nitto ridge Grappler 295/55/20 changing my effective gear ratio to about 3.88
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
