Both myself and friend of mine own a 19 Silverado 1500 (RST and Trail Boss). Same exact issues with the Fuel Pump Module. GM needs to eat this one and put a bulletin out to repair a known defect.
Sounds like a lot of guys real frustrated with this issue.
I’ve given up on dealers.
buy the part off eBay and replace yourself. Two screws and one clip….. very very easy
2020 Chevrolet Silverado RST 4WD 5.3 V8 Fuel Pump Control Module Failure less than 20k miles.
Dealer said may be a month and is renting a car for me but wants me to kick in on the cost.
Not happy about this at all !!
Buy the module and do it yourself. $50
I am having a similar issue however my code was a P0498 EVAP emission system vent valve circuit low. Replaced the vent valve solenoid but still had light. Replaced the purge valve solenoid but also still had light on. Took it to the dealer and they say the fuel pump flow control module needs replaced but is on b/o. Waiting to hear when they think it might be in. Seems to me $500 is a bit steep, isnt it mounted on the side of the frame?
Is there any reprogramming necessary afterwards?  Should I disconnect the negative the battery while swapping out the part?
Must be a bad batch of modules or something.
Na just plugged and play
Just purchased a brand new 2022 GMC Sierra 1500 Limited with barely 700 miles. A few days ago, the Service ESC, Check Engine, Engine Power Reduced and StabilitTrak lights came on! Took the truck to local Chevy/GMC dealership and was told that I have a bad fuel pump! Part is on order (May 11th 2022) so let’s see how long this will take -_-
May 13th got my truck back in full working condition! Turns out that it was a bad fuel pump (on a 2022 truck!)
I just had the exact same thing happen on my 2020 HC.  It is at the dealer now and they don't know how long till the parts come in...
Has anyone had a second failure?
I Have  a low pressure  fuel pumpproblem as well on 2020 silverado 5.3
Covered under warranty but part is on "national backorder".  2 previous versions of the part but waiting for the 3rd version
5 weeks later still waiting on part.
Any one have similar problem?
My 2020 Trail Boss has been in the shop several weeks now.  The fuel pump is bad according to the technician.  Fuel pumps are on national back order according to customer services.  They don't have any idea of when the part will be in.  I am very upset.  Customer assistance offered to pay the truck note, but I have to pay the tag and insurance ($250 per month).  That can get expensive fast on a vehicle I cannot even drive.  And I am worried about the income tax ramifications of them paying the note.  At some point doesn't the lemon law kick in? I am seriously over this truck.
  • 10 months later...
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
