I have a 2022 Silverado RST bad module and only 8k miles. Part is on back order nation wide! Dealer saying 2/3 weeks. I need to get compensated for this bullshit. 60k piece of ******. I should have kept my 2013 GMC Yukon with 140k miles and never been in the shop. 😡
  • 2 months later...
I have a 2023 AT4X 6.2L.  At 2750 miles the fuel pump went bad. Motor went into limp mode with reduced acceleration. Took my dealer a week to even get to it. Found out the fuel pump was shot, trailer break controller was bad along with 13 codes thrown. Truck has now been at the shop for 4 weeks (both parts were backordered) plus the week it took to get it on the schedule, so 5 weeks total to date. Had to insist they rent me a truck. Hopefully this is the last time its in the shop for anything major. Pretty ridiculous to see that similar issues have been going on for years over multiple model changes. Get you ****** together GMC! You're certainly charging premium dollar to us, the product should reflect your sticker.
  • 4 months later...
I have a 2022 Silverado and got stuck in remote area. Starter works no turn over threw a code p129f fuel module. So now 3 days later truck still broke down in remote area. Trying to get a wrecker to it.  This is unsatisfactory and Chevy should have replaced them before it went bad. Vehicle still under full warranty. The cost is the towing at this point. Hope insurance and Chevy warranty helps out.
I have a 2020 Sierra AT4 and having codes p0499 & PO488.  Does anyone know where the location of the fuel pump control module is.   There is not a lot of good information that I have found so far as to location and replacing.  Frustrating is an understatement.  Thank you for any help!
I'm not a member here but I do  have a 2020 sierra with 75,000 miles on it and my fuel pump control module is going out. There is a federally mandated emissions warranty on them for 8 years or 80,000 miles. I am having mine replace at the dealership under warranty. The dealer should inform you of this. If you have had it done you should be eligible for reimbursement. I just learned this with mine. Check into it.
  • 5 months later...
2019 LT w/only 31K.  Would hesitate sporadically and a couple of hard jerks but didn't think too much of it.  Was going down the road doing 55-60 and suddenly hard jerked and check engine light showing "no fuel".  I barely made it into a park.  Had it towed and sure enough the mechanic had to replace the fuel gas module.  I am at a loss that this issue is widely known and yet we pay good money on a truck that GM knows there is an issue.  Of course my 3 years is up but my mileage would have been under warranty.  May look into an F150 next time.
On 3/27/2024 at 8:12 PM, SilveradoRST said:
Is there something I can do to avoid this failure?  Is it the luck of the draw manufacturing defect?
No nothing you can do to avoid this failure. Fuel pumps and modules have been going out since cars were first invented.
  • 4 months later...
I had a P0499/498 and took it to the dealer. I ask about the Emission warranty until 83k as shown on my owners portal and the dealer advisor told me it only covered the catalytic converter and PCM in Georgia.. cost me 665.00 to get it replaced for the fuel pump control module.. so how did the gentlemen in the earlier comment have his covered? Gongrats to you mate. My truck is a 2019 LT trailboss with 55,700 miles on it. Really like this truck but its about one more check engine light from getting traded for a Ram Rebel... 7 times to the shop in 55K about had it.
  • 3 months later...
23 5.3 1500 LTZ with 16k miles.
I’m fairly certain the same problem.
We were on the way to lunch and going through an intersection when the engine cut. It wouldn’t fire up; just turned over and over.
Called a tow truck and had it dropped at Chevy.
2023 Sierra SLT 5.3 with 11k miles (at the time).
About 2 months ago, my truck suddenly would not start one morning, and I'm still under factory warranty. OnStar authorized tow delivered it to the dealer. Cause was a failed fuel pump power control module. This may, or may not, be the same as the fuel pump issue the original poster mentioned.
Here is the info from my service record if it helps.
Campaign: 24-NA-139
Service finding: code U18A2, loss of communication with fuel pump driver control module
Part replaced: 13554821
Just got my truck back; was same thing. Fuel pump control module was shot. They had them in stock; took a day to fix.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
