2nd day of owning this truck got this same code...  I hope there is a fix and that driving with it isn’t so bad because my schedule is hectic and dealer is a little ways away.
Edited by BillP89
Still working through this issue.  Been to the dealer several times.  They have a few 3.0 Duramax trucks that are experiencing the same thing.  GM Engineering is now thinking it is a leak caused by a clamp.  New clamp is on back order so I will bring the truck back in once the part is available.  This back and forth is driving me crazy!
My LM2 had this code, dealer performed a service on recall N202300791 to reflash the ECU or module that controls the DEF injection. They also replaced the failed sensor. I only have a few miles on the truck since this fix, hopefully the CEL stays away.
1 hour ago, gearheadesw said:
Wow, so no diesel in my future. Only in America can we totally screw up a diesel.
My LM2 has been solid with just a little over 5K on the clock.  Had a TSB for the shifter but that would be with any Silverado. Gas mileage is great.  Last trip I had 520 miles and 3 gallons left on the small 24 gallon tank.  Diesel is only .05-.10 more in my area
Edited by BurnsMax
Added info
Hey everybody, just wanted to update my experience with the P 1488 code. So after 7 trips to the dealership to fix this issue, I was given a letter from “GM senior engineer “ that there would be a recalibration done in September. Well this was back in late May and I had had enough of the issue, so I filed a buyback/ repurchase request. I really like the trucks performance and MPG.  GM bought back my truck and I got an almost identical truck in return. It took almost two and a half months, but it finally got done. I got an almost identical truck thinking that the issue was very limited and wouldn’t have to deal with it again.
Well guess what? My second truck has this same damn code. I thought that I would be done with the issue, but now I have to wait until next month to see what this recalibration is going to do. I will keep everyone posted as to what happens with this so called recalibration.
Hey Rockyblue, the clamp issue you posted is the first I’ve heard. Please keep us updated if the repair works or not. Thanks
Definitely update us!  Thanks
There's no denying that modern day diesels have serious problems. Just check this thread, yours might not, but it's very, VERY common, from one ton trucks down.
One ton trucks?  Hell it's with the big rigs too!  The emissions stuff really screwed things up.
Sorry been so long since I have posted here.  Still wrestling with this.  My dealer is Ed Bozarth Chevy in Colorado.  I am in the same dealership as another owner who had his in the shop for over a month and Chevy bought back the truck.  Mine is up next.  The clamp issue didn't turn up anything.  GM engineering shipped out a whole new exhaust assembly for the other truck owner but that didn't work either.  I like the performance on the truck but don't think I can pass emissions with an engine code.  Not to mention the possibility of going into Limp Mode which I've heard can happen.
Down at Park Meadows?  That is my neck of the woods.  They always treated me well every time I had to deal with them.
Ed Bozarth is pretty good. My engine is great but truck has weird infotainment quirks and climate control issues. No matter how good the dealer is they only can do with the provided FSBs or TSBs to do. This is a bad on GM, and the USA in general. ALL PARTS need to be made and assembled in the USA; I'd pay more for that.
Yes that is the one.  I will be taking my truck to them next week to start the process.  30 days in the shop for them to try and fix.  Then start the buy back process.
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
