I'm just fine and dandy with DFM
Thos is with 89 octane
I might possible could've squeezed 600 miles out of a tank! That's incredible compared to 375 miles as before on my 07 Classic, that got a damn respectable 17/19
I was too until I found a striking comparison that every vehicle that’s had issues was running with no cylinder deactivation tune.
Btw, did my Amsoil OCI today, I was shocked to find my oil pressure was much higher than when I was running OEM and Wix XP oil filters.
With Wix filters oil pressure was much lower at idle, this pic is of the Amsoil 25k mile oil filter, excellent oil pressure flow
b36ff3291383854afce096b59a991594.jpg6a9e2afabc71e6012cf885c4cf0a3b59.plist
Sent from Above
  • 10 months later...
On 2/13/2020 at 6:18 AM, Thomcat said:
According to the chart in the first link Corvettes use AFM, not DFM. And as for  the 8 speed of a few years ago running that hydroscopic Dextron that screwed with interior components ....yes.... problems, but not necessarily caused by AFM , certainly impossible by DFM, and not shared with later trannys running the new Mobil1 HP fluid from the beginning, or 100% changed soon after operation before it could cause an irreversible effect on tranny operation. That's purposely why I bought a post 3/19 production 8 speed....to assure it came from the factory with a belly full of Mobil 1 Synthetic LV ATF HP! And no engine vibration orshudder in my tranny running that combo. So, no need to be a guinea pig trying one out on a new advanced system with different operations and processors.
If you're talking AFM, yes, they're crap no matter what you throw them in....they've been kludging them since my '07 Avalanche...and the driver (not just the tranny) can feel the AFM kick in .. ..oil ring clogging, wearing and turning into oil burners and a POS valve cover that sucks oil from the upper end and dumps in the induction system, that's why you need a catch can......nasty harmonic for the same 4 dead cylinders at a specific speed, etc. Numerous TSB modifications including 3 versions of revised valve covers, two for shielding of the AFM discharge valve in the sump and numerous design revisions to the collapsible valve lifters....all around an engine designed for potential problems from the start with the same 4 of the 8 cylinders operating dead yet still pulling oil onto their colder cylinder walls overloaded with oil spray from the AFM discharge valve in the sump. I always used the range device AFM defeat device on long trips because continued operation with the same four dead, colder cylinders cruising on a long trip for a prolonged period wasn't good.
Couldn't wait to dump the fully kludged up '16 AFM in favor of the completely redesigned DFM arrangement eliminating the OLM altogether, new domed valve cover w/oil straining baffles to eliminate the need for a catch can, no more oil ring clogging AFM discharge valve in the sump, rotation of dead cylinder patterns to even out cylinder temperatures and not generate the same frequency vibration harmonic each time in operation. Actual performance of the same size DFM vs. AFM is remarkable..... control of the complex system required development of an advance processor to always keep the engine at full time peak performance. Seems GM finally relegated the AFMs to the retirement home, using up all old stock and you won't be seeing them on newer production vehicles.
Doesn't take an engineering degree to review the docs and realize DFM is a whole different animal without the same AFM flaws.
https://gm-techlink.com/?p=11880
https://gmauthority.com/blog/gm/general-motors-technology/general-motors-propulsion-technology/general-motors-dynamic-fuel-management-cylinder-deactivation-technology/
https://gm-techlink.com/?p=11127
Well perhaps you should see what my catch can collects on this new motor. The low sodium to be dexos approved is fine, but the low shear stability that vaporizes the 0w20 oil is still a problem. A 5w20 maybe the way to go if the cold pumping viscosity is very similar and still dexos approved
So at the end of the day, should I keep the Range DFM disabler I bought and put in my 2020 Silverado LT or do I not need it?  I'm not mechanically inclined so I rely on the experts on this board to provide me insight and opinions.
That is a complete judgement call.  I don't think anyone buys the Range to gain MPG.  They buy it so they have a full V8 all of the time, not part of the time.  That is why I bought mine.  For longer road trips, where you really want the MPG savings while cruising at highway speeds, unplug it and toss it in the center console.  That is what I do with mine.
On 2/13/2020 at 5:07 PM, snork said:
nice thing about the C7 corvette is you can deactivate the dfm by selecting sport or track mode
I’m confused why you can’t turn the off the DFM by setting the Silverado in sport or tow mode...I’m not positive putting the truck in L7 shuts it off either.
Edited by Luckyfd
Let me see if I can help clear up the confusion.
GM designed and built the SIlverado, Seirra and other vehicles so that the DFM could not be turned off by placing the vehicle in Sport or Tow mode. Therefore, you can't turn it off by putting in Sport or Tow mode.
I hope this helped.
JMHO
No expertise i plied or expressed
I hope this helped.
JMHO
Lol that was the most concise answer ever, thanks.
I bought my range the first couple of months they were available and have used it ever since. Most days it works great, but 3-4 times a month the engine will still stop. It makes me wonder if the dfm is actually disabled as there is no indicator and I don’t have duals. Does anyone know if there’s a way you can tell if the dfm is disabled?
Just a guess, but looking at the fuel economy numbers might help
On 2/12/2020 at 5:20 PM, Thomcat said:
Why would I disable something that I can't even notice in operation anyway? Besides gizmo has to be temporarily removed for inspection or servicing restoring DFM function.
These engines no longer use an OLM like the previous AFM version, DFM uses block mounted oil control solenoids for each cylinder which are constantly cycling. Doesn't seem to be any long term studies on the effects of keeping the oil control solenoids or collapsible lifters static for a long period of time and then reactivating for inspection or service.........and I have no desire to be the guinea pig that finds out.
Does anyone have info on completely removing the hardware for DFM?
85,000 miles and the lifters ate the cam on my BIL's 2019, GM says to pound sand, dealer wants almost 10 grand to replace the cam and 16 lifters
Edited by Krom
10K hahaha. The dealership is such a scam.
Anyway, the complete delete usually involves replacing the cam, lifters, oil pump, and various other parts.
In your situation, I would probably replace the motor, and reprogram the computer to disable the DOD/AFM/DFM.
Here are a few links, to give you an idea of what the options are:
https://sdparts.com/i-24138746-sdpc-l83-dod-afm-delete-kit-for-2014-2018-gen-v-5-3-engines.html
https://www.ebay.com/itm/133572585048?hash=item1f198be658:g:Di8AAOSw0axfqrnF
https://www.amazon.com/Qzucar-Active-Management-Disable-Device/dp/B08LL8BB8G/ref=sr_1_13?crid=2JYVGTRS66P95&keywords=afm+disabler&qid=1640480642&sprefix=afm+disabl%2Caps%2C221&sr=8-13
I agree that the DFM is a much better design than the AFM, but we are still seeing lifter failures on new trucks. When my 2021 5.3 with DFM turns 8000 miles, I will plug in the Range. I don't think this is a 100% effective way to stop lifter failure, but I can't believe that disabling the collapsing of the lifters will not slow down the failure rate.
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 765 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
