Message added by Zane,
Hey everyone, we noticed this question comes up a lot, so we finally put together one master cheat sheet. It covers the exact oil capacity, filter numbers, and drain plug torques for every GM truck and SUV from 2016 through 2026. Bookmark the full guide here so you never have to guess again: https://www.gm-trucks.com/gm-engine-oil-capacity-guide/
I just run the OEM filters for piece of mind while it’s under warranty. Haven’t heard anyone have issues with denial of warranty due to aftermarket filter, but I don’t like to give them an inch to deny me. 99.9% nothing will happen to the majority of truck owners. But yes the OEM ones are cheap crap. I don’t dispute that. I do 3k miles changes anyway. Just my .02.
This is 3,400 miles of Peppers winter driving with Red Line 0W20 and a K&P SS mesh filter filter with a beta of 35/1000. Yea, 99.9% efficiency. Mobil 1 claims 99.9% efficiency at 30 micron but wait for it...….
Wiped the stick on a white paper towel. Flows 7X more than paper clean and 2X more when it's 80% plugged vs a clean paper element. Bust strength a certified 1,000 psi. If the oil will flow it will be filtered and NEVER go on bypass and yes it has a bypass. Will flow 1.9 gpm per square inch with 1 psi delta.
Edited by Grumpy Bear
It’s the professional series that’s junk, the Gold series is a much better filter. Ultra sonically welded BS! It’s cardboard lol. The Gold series is a better built filter but still died to have reinforced wired backing like you’ll find in the aftermarket manufacturers. To each their own but holding a freshly cut and unused filter and thinking it’s a robust filter in anyway is nuts, it’s garbage. Thanks for posting
Sent from Above
Just curious. Any thoughts?
97cf4e97174f92e3960dc4c1497a6402.plist
Interesting, not one for reusable filters
Sent from Above
Looked at those and a few others. What I didn't like was the way the filter makes up. Takes a special tool and almost always separates when removed. Thread unwinds. Sort of a pin wrench thing.
The K & P is a tabbed lock. It can't come apart and yet is easy to disassemble for cleaning.
There are a few others who are flat K & P knock offs.
the real true oil filter inspection test is after you have used it for 5000 miles,  you will quickly see the quality of the media from all those heat cycles and pressure changes.. the cheap filters only last 2-3000 miles then when you open those up the filter media will break or crumple in your hands if you run them up to 5000 or more miles...
·        Lifetime (steel mesh) oil filters are not cost effective and there is no data that shows effectiveness.  Instead of throwing away a disposable oil filter you now have to dispose of cleaning solvent that also can be hazardous to use or dispose of.  Also, if the oil gets changed somewhere is it likely will get throw away.
Just another gimmick.
Interesting Opinion
AMSOIL filter v K&P cost wise is break even at 10 oil changes. For me that was 50K miles. If you use WIX or equivalent then it may take 100K miles to break even. You could stretch that to 200K or 400K if you use $3 dollar filters and change oil once a year. Anything is possible. But as the term 'effective" was used then yea, they are cost effective. Filtration effective.
Testing: https://kandpengineering.com/technical-information/testing/
Need more? https://www.challengeraviation.com/OilFilterengineappguide.pdf
FAA isn't allowing untested, ineffective and defective parts in aircraft.
This product got it's start in Pro Stock Drag Bikes.
Waste disposal is zero filters and a spritz of brake cleaner. Could use MAF or carb cleaner or if your really about the safety you can use hot soap and water and a soft toothbrush after blowing it inside out with a bit of compressed air and letting is dry for a few days.  What waste? ZERO waste. I have two elements to rotate.
My mechanic isn't that stupid. If yours is, find a new mechanic. If you ARE that mechanic....:rollin:
Who it doesn't make sense for are people that trade every three to five  years. The Jiffy Lube crowd.
Interesting Opinion
My mechanic isn't that stupid. If yours is, find a new mechanic. If you ARE that mechanic....default_rollin.gif
Hey! I traded ever two years but really enjoying my current truck and I assure that I DO NOT use jiffy lube lol. Everyone’s got a system, I enjoy getting to tinker with my truck, changing the oil myself helps me see what’s going on with my engine, IMO switching out oil filters should be just as simple without cleaning to reuse but hey, to each their own [emoji6]
The chrome filters do look sweet though but unfortunately, no one but me will know it’s there unless I install a chrome bypass filter under the fender well. Nah, that’s something a show truck would look good with.
Sent from Above
for the cost of a K&P filter I might as well buy a Frantz oil refiner,  run in by-pass mode, the filters only cost $2-5 each and filter to 1/10 of a micron, will full lab data to back that up.
then just leave an ACdelco Gold spin on installed for the large contaminants  , now I'm getting anal about my oil quality...
Edited by flyingfool
  • Zane locked this topic
This topic is now closed to further replies.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
