4 hours ago, TheeSpaniard3500hd said:
Has anyone tried to mount the camera with adhesive tape instead of putting holes in the back of your trailer?  Curious if it will hold with the rough ride of a travel trailer?  I’m going to install my camera this weekend.
Yes, I installed mine with 3M automotive tape back in March with no issues so far. I also spun the camera around so the cable came straight out the bottom instead of looping over the top.
Thank you.  I ordered some 3m tape to try myself so your feedback makes me feel me feel better about the use.  I was thinking about a smaller diameter self tapping screw in addition to the tape but really would like to avoid holes in the back trailer wall. I plan to run my cables underneath too.
Yeah, there was no way I was going to drill a hole in the wall of my new travel trailer! Seems to work great, knock on wood....
Mine is held on the rear glass window with 3M tape.  I'm pretty sure it won't fall off and removing it would be a chore if I ever decided to do sol
  • 2 years later...
On 3/10/2020 at 5:09 AM, MTU Alum said:
If the truck is calibrating, then the dimensions should be fine.  I would first look at the angle of your camera, it needs to be at 35 degrees (0 deg is straight down).  For calibration, you need to drive in straight line under 30 mph.  I like to exit the trailer app and select the transparent view in camera app.  There will be a status bar at the bottom that turns yellow as it calibrates.  My understanding it is will only calibrate during daytime.  I have also seen issues with spare tire and shadows that the system does not like during calibration.  If you are still having problems, post a picture of rear camera view and camera mounting on trailer.
#iworkforGM
I get the “Needs to be Calibrated” screen. Drove about 20 miles, but never got the Transparent Trailer view, just the split 3 camera view and the blind spot warning when I turn on the blinker. Any ideas how to get the Calibrating to finish properly? 2023 Denali 1500 with OEM GM trailer camera.
Attached a few photos.
14 minutes ago, MTU Alum said:
My suggestion would be to remove the spare tire and try to calibrate.  I assume you are driving under 30 mph correct?
Yes, I drove 25 mph but never saw a progress bar under Invisible Trailer view in Camera APP. I’ll remove the spare tire and see if that helps. If it works, can I return the spare, or should I use the time to relocate it somewhere else?
You can reinstall after calibration.  If you still have problems, you may want to change one dimension by an inch.  It sometimes doesn't like shadows, so may need to drive in opposite direction if you see a large shadow.  I hope this helps.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
