What would you do in this situation?
Hey all,
So, long story short, the dealer has done some warranty work on my truck, damaged a lot of parts each time so I raised hell (in a calm and conducted way) to the dealership general manager and service team.
They are offering to get me into another truck of my choice with a pretty decent deal, but in my opinion they shouldn’t be making any money on the deal so it should be better.
Current truck: 2019 1500 Denali, 5.3 2wd 8-speed
New truck: 2020 1500 AT4 5.3 10-speed - only thing that it doesn’t have that I want is a sunroof but with Gm not currently producing trucks, would be hard to get exactly what I want.
They are taking $12k off of the AT4 and offering me $43k for my truck, I paid $45k in November and only has 1400 miles on it.
I think it’s a decent deal, but like I said they shouldn’t be making any money on it. Does anyone have any idea what I should push for? I think I should only be paying difference in MSRP, but I know the dealer would disagree with me.
Trying to be calm and realistic but also need them to make it right without much of a financial burden on my end.
I wouldn’t be upset with this deal personally. It’s hard to know whether or not they are making money on a deal. The trade in seems about right and the money off seems about there too. I probably wouldn’t sweat it to get out of that truck which seems to be cursed. I also wouldn’t ever use that dealer again.
I pretty much feel the same way, especially not using this dealer to have service done again. That being said, this was all done via text with the sales manager. I plan on going by this weekend and if they’ll meet me half way with another $1,000 or $1,500 in person I’ll probably pull the trigger.
Id jump on it and ask for the 0% financing ... heck yes.
Doubt they’ll do that since it’s a GM based deal and not through the dealer but you never know. I’ll ask for sure!
Let's see?????....you are offered a one year newer truck which equates to about $4K in KBB value for the price of a sunroof and none of your current problems..
I'd say Thank You, buy them a box of cookies and in the future take it somewhere else for service.......or you could just keep your messed up one for free.
Real difficult decision.
Is your current truck going to be a buy back?
No, they are going to purchase it and just send it to auction. GMC is involved but I know it takes a long time to get the buy back going and I’m not sure if gm would even do that since it’s mostly the dealers fault for the damages.
Have they used the verbiage "trade allowance"?
If GM is taking possession of the truck, then the deal should be pretty solid on the trade.
Where is the 20 at right now, they should be giving you the option of a truck of your choice, your dealer can locate one from another lot if there is one to your liking.
That is what happens to the trucks when they are bought back by GM.
If the dealer wants it for their stock, they have to find what auction house it was sent to and buy it outright.
No trade allowance has been spoken of, just the dealer trying to make things right on their own. They said they might be able to get me another truck from another dealer but without gm involved they are having a hard time getting a dealer trade with no new inventory coming in. This truck is exactly what I want, just missing the sunroof which I can live with.
I went through a buy back in 2013 so am familiar with the process. While it’s great and it recovers a bit of money, it’s a heck of a process and if I can get close to where I want to be without GM involved it’ll go a lot quicker and smoother.
You live once, if it makes you happy, pull the trigger.
It is always a good feeling driving a truck that you like and trust, rather than waiting for the next problem.
Have gone through both trade allowance and buy back, you are very correct, neither really fun stuff.
Cool Nova by the way, (my apologies if it is a Falcon) hard to tell in the avatar.
    • Ancillary parts to the lower intake and connections went together without issue.   There was a brief pause when I leak-tested the fuel lines and injection system. Fuel was spraying all over. Lovely. O-rings weren't sealing the fuel lines to the spider, and inbound line was leaking at schrader valve, leaks at both flange nuts. It's moments like those when you just want to set fire to the whole shop, and be done with it. I was mostly enjoying the project up until that point, and was tracking to an agenda of having a running Blazer and a cold beverage in hand by dinnertime.    I found some larger Viton o-rings for my spider and some grease to get them to seat. One leak solved. Swapped fuel line Schrader core for old core. Still leaked. Swapped entire valve for old valve. Leak solved. Nudged the flange nuts a little tighter on the connections. Another leak solved. I could cycle the key / prime the pump and the intake was staying dry.    Reassembled the upper intake, with 10,000 vacuum lines, and filled the cooling system with water* (this is temporary, I'm not done with the cooling system yet).   Showtime!!   Cranked it over and smoke billowed, it was running rough. CEL illuminated and began flashing. P0300 and I somehow tripped a code for the TPS sensor, voltage low.    There's nothing as unrewarding as a vehicle that won't run (and produces the same code/problem) after hours of research and work.   Clearly I was in over my head. Was the timing off, did I stab the distributor incorrectly? Is the new distributor bad? With my limited OBD 1.5 data stream I really don't have a lot of parameters to see. The engine was pulling mad timing again (flooding?).   Think, Atlas, think.   1-6-5-4-3-2. One, six, five.....four, three, ....two. Wait a second. That makes no sense. 1 is the forward cylinder on the driver's side, so 2 should be the forward cylinder on the passenger side, not 6.    I can't believe it, but I'm looking right at it. Swapped 2 and 6 on the distributor and turned the key over, and...   It fired, coughed and stumbled, smoked, and then settled into a smooth idle. The scanner showed no codes, no lights on the dash, and the throttle was nice and responsive to gentle revs while it warmed up.   It's working!!! IT'S WORKING!!!   I paused for a late dinner, no cold beverage yet. I was determined to do my shakedown run. Did a basic safety and fluids check one more time and then went out and put almost 70 miles on it last night. She's a runner, runs good.   Came home and did a post-trip, post-mortem. The underside is dry *except* for where the last owner RTV'd the snow out of the intersection of the timing cover and oil pan. He said he had replaced the timing cover seal, but, my dude had clearly done it incorrectly and then tried to hold back fate with black RTV. Never works.   Yesterday morning I replaced the broken driver's door mirror. As much as I hate cheap Chinese parts, thank goodness for cheap Chinese parts. I think an entire new power mirror assembly cost me like $30, and it works perfectly. Replacement tail lights (faded, and one was busted) ran me about $12/side. I have a door pin kit ready to go in because the driver's door sags just a little and I want to fix that because there's nothing sadder than a saggy door.   I don't know what's next for this rig. Half of me wants to take some nice photos (there's a park nearby with a HUGE American Flag that always seems to be catching wind) and throw it up on CL/Marketplace for a couple grand and see if it flies. The other half of me... I've got a sweet running S10 Blazer that's been keeping my mind off of whatever I'm going through right now, and it's bringing some joy, and is cheaper than therapy. Maybe I'll keep it around for a little while. However, this is my 5th vehicle, just for me. 4 is really my limit, but they are not junk, so need very little attention. I don't know...there's a point where it's just too much and I don't see owning this truck long term. But I solved its major problem, got it running, so I'm going to stick a feather in my cap for now.   Sometimes we just need to get our hands dirty and fix something in the physical world to gain some satisfaction.
    • Happy 4th of July! Be safe out there tonight
    • I bought the truck new in December 2022, and it's got 60,000 miles. The front cover magnet had slightly more glitter, but overall very clean, no off odor, and good-colored; really nothing to report. My truck has Hi-Lo transfer case, and the fluid looked great, as well. I have towed..maybe 1,000 miles. Yes, this was the first change for all three driveline items. I'll probably do the transmission at next oil change.
