U-bolts loose - might want to check yours!
After reading some posts about a rear "clunking noise" coming from the rear (which mine does), saw a bunch of guys citing proper torque specs for the rear u-bolts, as well as some talk about replacing the inserts between leaves, etc.  I decided to check mine this weekend.  The specs call for torquing them down to 60 ft lbs, then back off 1/2 turn, go to 60 again, then another 1/3 turn final.  Well, when I went to check them, I started at 60 with the torque wrench, and had to crank at least 1/2 turn on all of them!  That means they were well UNDER even the beginning value of 60, let alone the final value of somewhere around 80-90 ft lbs!  Yikes.  I haven't driven it yet after doing this, so I can't comment on whether it helped with the clunk noise, but not good having the rear axle held on at less than 1/2 the specified torque value.
I'd highly recommend checking yours!
I just checked mine and wow were they loose. I torqued mine to 60 and then 75 ft/lbs. We’ll see how it goes. I am getting a rumble on deceleration so hoping this might be part of the problem. Thanks for the heads up!
I also noticed the trucks I have gotten as loaners didn’t have the rumble and they didn’t have pinion shims but mine does. Pretty interesting.
Curious, which plants were your respective trucks manufactured?
My truck was built in Mexico, and funny enough on a Monday as well. Lots of stuff wrong with it but slowly working it out.
I had the dealership check out the clunking noise coming from the rear when traversing sharp inclines. Picked it up and SM said they cleaned and lubed. No noise for a couple of weeks. I finally got around to crawling under the truck tonight to check the torque on the ubolts. First pass was at 60 lb ft. And not a single one was torqued to 60. Probably needed  1/2 turn to get to 60 then I torqued to 75. I will see what it sounds like tomorrow. Bottom line is you need to check your u bolts.
Where are these U bolts located? Does anyone have a pic or can explain where these are so I can check mine?
Edit: if you are talking about the bolts for the leaf springs I just checked those and mine were not even at 60 ft lb. I tightened mine to 60, then 70, then 85 ft lb.
Did you have any clunking noises before tightening? Mine is better but not completely gone.  I think I will tighten to 85 and see if any further improvement.
I do have a clunking and I thought it was my rear end locker engaging and disengaging. I just tightened these down about 30 mins ago and have not driven it yet. But I do hope this helps
I have something similar coming from the rear when slowly navigating the driveway, speed bumps, or uneven roads.
Just called my local dealer, they said the torque for when adding the trailboss kit is 53ft-lbs for the ubolts.
I got no turn at 50ft-lbs and a couple of degrees when torquing to 55ft-lbs.
I am having another dealer look into it also just to make sure. I will have to re-torque again tonight
Other dealer sent me this, Thankyou Fremont Chevrolet.
NOTE: I have a regular 4wd(not Z71)
That’s about what the first post said - curious what the exact final torque value is. Somewhere in the 80-90 ft lb range it looks like.
Makes me wonder why they wouldn't just put the final torque spec?
From what i was told(fremont chevy), they are torque to yield bolts (not reusable).
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
