Come'on good buddy!
Has anyone installed a CB radio or Ham radio in the new 2019s+? I have a jump seat and there's more than enough space in the middle there to mount one.
For a mag-mount antenna, is the roof aluminum?
I haven't yet, but I plan on it. Although, I don't know why. Nobody is on there much anymore, and most of those that are aren't worth the effort to talk to. I inherited a friend's CB shop when he died. I've got more radios and equipment than I know what to do with. I don't have a problem with drilling a hole and mounting it right in the middle of the roof. They make a plug to fill the hole should you decide to remove it. GMC dealer said if that rubber plug is installed, it won't hurt the trade-in value at all......if they even see it. Getting in the garage is the only issue I'd have with it.
I put one in mine with a full center console. I hate mag mounts. Drill it. I leave the mounts in when I trade in because they’re super cheap. Dealers don’t even notice. They’ve never asked about them and that’s with the antennas being in place when they evaluate it.
Here’s a pic of someone else’s install so you can see what’s possible:
I have a K2, but I screwed my bracket into the little door that opens and shuts on the underside of the dash in the middle. I'm running a Beartracker 880, the CB/scanner combo unit from Uniden. Check it out, it's pretty sweet to be able to hear Police/Fire/EMS and other digital trunking systems that every service seems to have now.
It has 2 antennas, 1 for CB and one for the scanner. The scanner antenna is internal to the cab and works just fine that way, my CB antenna cable I route between the jumpseat and passenger seat, under the mats, up along the driver side B-pillar and out between the driver and rear door on the driver side so that it escapes through weather stripping with no pinching.
You may be able to do the same.
Also, FYI, the 980SSB and 800/880 use the same mounting bracket and microphone, so you can interchange head units as you see fit.
I also use a magnetic mount Tram 3500, it's a 55" with adjustment at the base for SWR tuning (use a meter, don't smoke your radio), and it's rated for pretty high wattage if you choose to use an amplifier. I'm close enough to some big highways, so I don't see the need for one.
I will say I have DXed with that antenna on my truck with my gain all the way up, SWR at 1.1 out to Texas.
Sent from my SM-J810F using Tapatalk
I may get slightly better performance on the scanner if I had a roof mounted 800/900 MGHz antenna, but that's a function I prefer to keep "stealth". From an outside observer, I only have CB.
Outside observers hardly ever notice antennas ifk
You are probably right, but I like flying well under radar.
I can definitely confirm that an officer that stops you hates hearing themselves through your radio when you have a mic attached to the unit (which only works on CB, but they don't know that).
I got my ham ticket a little while ago and haven't used it much. About 2 months ago we took a roadtrip, about 400 miles each way, tuned my handheld to the "highway channel" for hams ( 146.52 ) and I didn't hear a single click in 8+ hours of interstate driving.
However, the CB in my area (NEFLA) is fairly active. It's not quality conversation, but at least there's activity out there, and it is useful in traffic.
I was thinking about something like this:
Or maybe something in the bed.
Any thoughts from the experts?
Drill it on the roof and be done with it. Best option out there. Drilled this one with 400 miles on it. a6dfcfe7a31cb61085224680e193b169.jpg
Thanks @Jav_eee   this is what I was looking for. Do you have any pics of your setup inside? And how long is your whip and hows the reception/SWR?
Edited by nichos
Nothing wrong with mag mounts if you get a good one as far as performance is concerned. I've run the Wilson 5000 and 1000 both on a mag mount and put 300-400 watts thru them. I don't like mag mounts because the coax situation and if you don't remove every so often, they will rust underneath the magnet. Much neater to just drill a hole and be done with.
5 hours ago, Jav_eee said:
16” from the back of the metal roof to the front puts you in the perfect spot. DO NOT measure from the plastic spoiler
How far down did you take the headliner, and how easy was it?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
