This thread will have all my mods for my truck will be alot of post over the next few weeks
SOME POST WILL BE MODIFIED TO ADD THE FINISHED PICTURES
PLEASE PM ME ANY QUESTIONS ABOUT ANY OF THESE POST
Pictured next to my 15 1500 with 2 in lift
Sent from my Moto Z (2) using Tapatalk
Edited by mkeddie
First mod
nfab running boards
First holes drilled
Back rack on
Edited by mkeddie
Torn apart....
lots of parts and pieces to get behind the dash to run wiring
Edited by mkeddie
What are the holes for?
Fire radio
Red CONSTANT power (unused sunroof 40amp fuse pulled)
Yellow IGN power (would assume 50mp but not sure )
passenger side fuse panel
Edited by mkeddie
Got the dash back together and pulled the back seat...
Wasn't easy to figure out but now it will be a 5 min removal
lots of interest on how to pull the seat so there is a post below with a writeup on how to remove
Now to figure out how to cram 4 more electronics boxes in there 2cd199e1e8ecb4e75465372d6d4cb786.jpg60e897b9ac2ede61afea6275b2447870.jpg
Edited by mkeddie
The grille came out for siren install and grille mod/replace( retrofitting camera into other grille)
Center Chevrolet part Currently out to paint 480a935dfae8aa0b5605ec849918c3f8.jpg5b97c28b470d654e164f06b099a3a358.jpg6acf306138e114717abf8e1598fb6b32.jpgf8e07ba7e5b935c21aee14271f7c5cbd.jpg79358e27546330a8186280db90ef17c8.jpg
ab380635596c2d0e79bbf1457c095883.jpg1de923d2ab52ad90712dd8c22ceb49f9.jpg92ef254a9f6ec232c56e4fe97e3a3f81.jpg
Will you be ale to modify the front end to make it easier on the eyes like your 15?
Yes it will look more like this e0b1c5e51b1ba872e9180add94b01006.jpg608a7e2a875a80f8111000b503ff09f2.jpg
On 5/6/2020 at 6:24 PM, mkeddie said:
Torn apart....
lots of parts and pieces to get behind the dash to run wiring IMG_20200506_182159053.jpg
How did you route the wires out of the cab to the light bar that’s on the back rack?
That will probably be posted tomorrow
Been busting thru these projects taking pictures as I go
Here is how I routed all my wiring
They are all weather tight electric connectors
37dd88f8da3e42aca436632209659992.jpgb3a9e613c6369d240e8cd12ea21ec1f4.jpgb31fa063667c92e0bbc0df7d357ebc86.jpg315005296bccec34f8bb33ea0d04b707.jpg024b43330998b771674baf33fecfdbfa.jpg48c2ebbef4d37fbb4f77816c220186f4.jpg
    ncleg
    ncleg
  • Who's Online   6 Members, 0 Anonymous, 983 Guests (See full list)
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
