large mud guards
Does anyone have the larger gm mud guards installed on a sierra, and could post a couple pics? The GM accessory site only shows extreme close-ups. I have a ton of rock chips already and am trying to decide between these or after market
  • Replies 32
I thought I saw that drilling is required for the factory mudflap upgrade. That pushed me to get the weathertech no-drill mudflaps. Tip for installing the paint protection film under the mud flap is to hold it up as tight as you can, then masking tape 1/4” off the mudflap. Stick the film about 1/8” off the tape. Go in with a plan to make both sides the exact same, if you care.
oh, this is for a Chevy. Of course they’re not the same.
One thing about the factory mudflaps, they are very stiff. They don't have much give and might damage the body panels specially the rear ones if they hit a hard object or bottom down in a ditch crossing manuver
Good luck!
Mine came with the larger mud flaps installed. I'll see how they do with the new wheels I'm getting tomorrow. I might look to switch up to the factory smaller ones. Although, I do agree, these look like they do protect the sides of the truck20200430_140117.thumb.jpg.a1c72918b2e45177163c27ae0be92b9b.jpg better.
Same here, also installed from factory.  As mentioned above they are pretty stiff but I don't mind as they don't move around when loaded up full of snow and slush, and they seem to offer a good amount of protection without being an eye soar.
sO6jL4c6il0Bw1-CvungEOzGqWyjmpIxUQ7tLDfefSI7Qp3-_PCL29q4uBduTAhHQNwkJ-2l9Q-5THQjUjkkjWjiRRdVOf1C0OrmkNjpyzod2hMaOw4mbT7PdgRBjpMMzHtMTPBsHj6uZepc8gwjDmEhIusB8BziGytD88DBiQo5-kw048s6wYwfV70y7cM2DcXLFUuqeDguiycaYmo7-MIIfsGNTT0etJhkxyatUa-1vmX7XMAEu7ba0QKBLvYcRQ3QNsC7Bx-8vi9tzboJlHIXMQIb_YnyYeCv8Acow9rBPEYvlkwHVj-NHXELWFIh81tSXsjjWkfRC8vjhD7bbDdf7NBewmYWAwL_KuectMq3ajBKheNzKZ6qBXnZgiEOXVbCzOBe1DUzmt_IgVCsYg0Tt9j0TDh3yUfP3p6r1dqtXd8HvSu3AknoV-wQENX1kBTZs9ESR7Jt72arCnNP1smMoFAFLFOUOpkqByXsnPvcPDE62k6PaSqZz1ap2FnNvUHWeA_5x0hLSCbf6h7Y6x_opjKzYHVT6TkH1wGjieuj68Onf0tJoGpiSKb3fFWI6mpaFX-Me8UZCC8YRcMEgtL4cEIuzngRl_IixKNJ_OnbK6rXZYAlZyHLFMmriQTjRRK11PctV1KimugNfZu7rrO5s59wt0GB-xtcZM_C6tIW_dGmVtkxqmubbIeK=w1129-h635-no?authuser=0
7hmEAmUcN0ka6O7Xf8KTGW_BjddxtSQzmzwrzRhHG3jFn-vrzj2Cv9gYQl_kOliGNTmXr4hAenTM-5ruvvC4zjwRSxWmcKK0ppenBTUzHGnpc4MgNyrlMxTPOBM7gsf3NT9j4-kbo0Q9les1idBrh4Cda7OwKVn_EDgyZJDOdsNPbhSQFlG22KNF08nYY9w7YCoNYoaXlPx9Ib2GtyvKZcSbbE3AxaP4UkI6tgbIg4qFzGgT_L53Fta416961EFLnRUoUL9zg7__EVrpNp_JNMpI50hRobtCTy3LqPv4nkrjcM8iUpmghYLTTQZcyF6onBItckDY3u-5dqht7Xladj0y7O98d9Xydvr-2q6SL_8DZwpSPbv5BpZyvAajM4t6kG5zvd0kRPikcWFRL85fDJHyohjdQKozyGcSgwoqraJQNIferXeo3CxbjX6yOdk60JGM6tA9KH9BG5TiHoXRVsRl4tXWB46R1_-j9K_NYCqnJURR0ksR9L3O_Pt_thZQQupmqA8JLFZuk57t1Zl7PHOiVAJ0Jw79V9p9cgcBYtJfxugmCC4J4IjYulsbxNLgR0MJulGP80D-zxn50WvUHh5QibC5NejuTnEIvCMxZLuibKY0a2nDUdBWu8ybrdD1tgGXKWwrd6IWMEaAQKK75nelBEWSKiJ0Gj0jZXI7wJY7a9CNcKic2RvW63Pb=w1129-h635-no?authuser=0
Thanks! Are they lower then the stock ones too, or just wider?
It has been awhile, but I believe that they are a little lower.
I just installed them last weekend. It was pretty easy but you do have to remove the tires and drill a couple holes. Also, it comes with 4 rivets for the front ones so make sure you have a rivet gun. Overall I like them a lot better then the Weathertech ones that my dad has on his Silverado.
This is an easy one.  Get the weathertech no drill flaps.  I have them on two truck currently.  Running them since 2007.  Good stuff
Did your truck have the smaller factory mud flaps installed already? I would like to upgrade to the larger splash shields from the smaller factory ones but dont want to drill any holes. Thank you.
I installed the larger GMC ones like shown in this thread, last Thursday. I like them, easy to install, need a rivet gun like was already mentioned.
My tip on the drilling part - I did not remove wheels. You are drilling into pretty soft plastic, so I literally turned the drill bit by hand and it got through in a few minutes. Just need a little patience. Probably took same amount of time as removing and reinstalling wheels. Maybe less.
Ok so it's just drilling into the plastic trim than and not the sheet metal? I'm not concerned about the drilling the hole part just the corrosion that will come from drilling holes in the sheetmetal.
Actually, no, you do have to drill into metal once per guard as well. So four total if putting on front and rear. I didn't think of that when writing yesterday because you can get to that spot with a drill and wheel on. I drilled into the metal and used some touch up paint and super lube in the area. But if you are worried about corrosion from it, you might want to take into account that the guards use metal U nuts, which could potentially move around and scratch the paint a little over time too.
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,493 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
