my center console wont open so have to go to dealership, I am pretty sure they are gonna have to replace it, idk if they can just get the lid open and not too sure they wont break it or something else just trying to get it open (I have tried and its jammed pretty good)....what are are my chances I can get a full center console (upcharge maybe?)....I think the whole console comes as a complete unit with seat as well, since I wont have one to sell after upgrade to recoup.....they should have checked vehicle over imo….I wanted bucket seats but their wasn't any available unless I went up to LTZ....anyone have any luck scoring an upgrade from defective part, I actually wouldn't mind paying a lil extra at all for full console as long as I get bit of deal for headache
I am waiting for dealer to call me to let me know my local dealer has a FOB and manual before I make appt for console
Edited by Dunn
There was a thread about this awhile back, I'm not 100% sure but I don't think there is a lid that opens on the LT trim trucks.
That would make a lot of sense why it won't open ????
Both my wife's 2020 HD 2500 and my 2020 1500 are LT's and they have opening lids on the consoles.
Can you post some pics of it open on the 2500, curious on what the latch mechanism looks like.
Maybe we can help the OP with what might have failed.
LT console opens, I specifically got this trim level because I am well aware of the custom trim that doesn't open....it has the latch, you can feel it wants too, but the pin is stuck or not engaging far enough to release it....I just traded in my 2019 RST with same console
on the custom and WT there isn't even a latch to press....mine has latch its just stuck and I can get it open if I break it but then it becomes my problem....currently its theirs to deal with
was just curious as to scoring the full floor console since they probably have to replace it anyway, I doubt they will even try and probably break it anyways, most likely they will just unbolt it from floor order the whole thing and send this one back....that's my guess anyway
Edited by Dunn
9 hours ago, MTU Alum said:
Work truck and custom trims don't have center console storage.
#iworkforGM
you thinks its possible I could just get upgrade to full floor console for bit of an upcharge?....idk what dept you work at over or is it not even worth bringing it up when I get there?
Edited by Dunn
  • 7 months later...
I'm having the same issue. 2020 Silverado 2500 HD LT Z71 package.  Anyone know if there's recall on the latch?  It seems the fold up seat and the cover operate on the same locking mechanism.  When the seat can be moved the cover stays locked  and vice versa.  On mine the seat won't lock into place and the cover won't release.  It's happened twice now.  The first time a few months back.  By chance, I was able to free it up the first time.   This time not so much.
Edited by 1JB
Spelling
I had this problem when I picked up my truck new from the dealer. The salesperson said she didn't think it was supposed to open. I told her it has a latch. It has to open. I didn't want to break it by forcing it. So she called someone over from the service department and he fussed with it for several minutes and finally got it to open. It hasn't been a problem since.
yeah i got mine to open with a thin metal bar and some pressure to pull forward and up for the latch back far enough to release it.......same as above hasnt been a problem since.....now one of my power folding mirrors wont close
My local dealer was able to fix the problem. The console lid and jump seat latch are set up to operate dependently.  If the jump seat is in the open position for seating, do not open the console lid.  That's how the latch locks up.  If it does happen, you have to pull the rubber cup holders out to access and loosen the latch mounting screws.  The cup holders can be removed easy enough, they just carefully pull free from the console lid.  With the screws loose, the latch can be moved a tiny bit to release the lockup.  The Servuce Manager told me the latch is not normally adjustable so don't mess with it if you don't have to.  The service trick might save a trip to the dealer.
Edited by 1JB
Spelling
  • 3 years later...
2023 custom trail boss, center council won't open, when you pull on the handle to open it feels like it is almost going to open, I have never even lifted the council for anyone to sit there. Pretty disappointed, esp for how many miles are on it, and I felt like an ass an was very embarrassed when I went through the drive thru at McDonald's and couldnt get to my money to pay.By reading through the posts this seems to be an issue in alot of chevys old and new, surprised they haven't fixed the issue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
