Not a duramax but is a GM diesel.  I use AMSOIL's Diesel Injector Clean + Cetane Boost in my 2014 Cruze diesel.  It adds lubricity and the extra cetane is good for better flame front burn in the cylinder and cleaner burn.
Edited by Black02Silverado
GM's  position on this, from the 3.0L supplement.
Basically, if you are buying quality fuel, it already has the proper additives.
cut and paste from 3.0L supplement:
TOP TIER Detergent Diesel is highly recommended for use with
your vehicle. If your area does not have TOP TIER Detergent Diesel,
GM recommends the use of ACDelco Diesel Fuel Conditioner.
This will help maintain optimal engine performance. GM does not
recommend other aftermarket diesel additives.
If low-quality diesel is used for refueling, GM recommends adding ACDelco Fuel System Treatment
Plus-Diesel to help clean engine deposits.
This is available only at your GM dealer.
end cut and paste
fwiw,
about 12 or so years running 6.6 dmaxes; LLY, LMM, LML and now L5P
I don't use additives.
I'm fussy about where I source fuel.
GM 6.6L supplement has similar message as the 3.0L
Edited by redwngr
end cut and paste
fwiw,
I don’t think I’ve ever seen the top tier logo on any of the diesel pumps here in eastern pa. Maybe not as widely available.
I have the same concerns here in eastern VA, as well as where I routinely travel, eastern PA, upstate NY and central WV. Guess I'll carry additive with me...
Following.
I don't have top tier diesel available near me. I bought some opti-lube summer+ but am nervous to put it in the tank without being more educated. Impulse buy....
According to toptiergas.com's diesel page, the licensed brands are:
Co-op (Canada)
Costco
Fast Stop/Express
Kirkland
So basically, the General is telling us once again to be sure to only use this specially licensed product, which may be hard or impossible to find in your area.  Just like DexCool and Dexos.
Edited by MaverickZ71
I haven't been paying attention to Top Tier' branding ( For the same reason you mention --  availability isn't widespread, the 'premium brands' don't seem to have jumped on the Top Tier Diesel thing.)
I never buy fuel from 'discounters'
As others pointed out, the fuel often comes from the same terminal.
The brands add there own additive package, which is one of the reasons 'premium' brands are sometimes slightly more expensive.
I also source from larger volume locations.
Just not large volume 'discounters'.
Co-op (Canada)
Costco
Fast Stop/Express
Kirkland
That seems suspicious to me. Co-op is the only one of those that actually refines fuel; all the others would have to buy their diesel from another company. So unless they're buying all their diesel from Co-op (who I believe only have one refinery that's shut down more than it's operating lately), how could the diesel be top tier from  the resellers but not from the original manufacturers? Could the manufacturers' additive packages not be approved for top tier fuel? That seems unlikely too, given how big a business diesel is.
I agree the list seems odd.
My understanding is the additive packages get added at the fuel terminal, not at the refinery.
Fuel in pipeline from refinery can end up at multiple fuel terminals. Fuel at terminals can be distributed to multiple 'brands'.
Each 'brand' can then have it's specific additive package.
Seems like I’m always either filling up at a Sunoco or WAWA in my area. Not sure if the wawa is Sunoco supplied fuel or not. I always see PennDot filling up there trucks with it.
Here is that full piece redwngr referenced:
Quote
#03-06-04-017N: Information on Diesel Fuel Additives - (Oct 14, 2019)
Diesel Fuel Additives Are Not Required or Recommended
TOP TIER Detergent Diesel is highly recommended for use with diesel vehicle. If your area does not have TOP TIER Detergent Diesel, GM recommends the use of ACDelco Diesel Fuel Conditioner. This will help you maintain optimal engine performance. GM does not recommend other aftermarket diesel additives. In the event you refuel using low-quality diesel, GM recommends adding ACDelco Fuel System Treatment Plus-Diesel can help clean engine deposits and is available at your GM dealership.
Common Diesel Fuel Concerns
Fuel Waxing/Icing
Fuel distributors blend #1 and #2 diesel fuels* for seasonal requirements in a particular region. No other blending of fuels is recommended. However, a customer may desire to use a winter fuel additive to prevent fuel waxing or icing during extreme cold snaps. If a winter fuel additive is to be used, it must not contain any metal based additives, alcohol or other water emulsifiers that may compromise the water removal effectiveness of the fuel filtering system.
*In Canada, Diesel fuel blend #1 is categorized as type A (Winter) and blend #2 is categorized as type B (Summer)
Bacteria and Fungi Growth
Bacteria and fungi growth can occur in diesel fuel when there is water present, especially during warmer weather. The best prevention against bacteria and fungi growth is to use clean fuel that is free of water. There are diesel fuel biocides available which are designed to kill bacterial growth in the fuel system. However, the dead bacteria can still cause blockages throughout the fuel system. If bacterial growth is found in the fuel system, the proper method of removal is to flush the fuel system using the appropriate Service Manual procedures, replace the fuel filter element and refilling the tank with clean diesel fuel. If a customer desires to use a biocide after flushing the fuel system, it must not contain any metal based additives, alcohol or other water emulsifiers.
Low Cetane Number
The cetane number is one indicator of a diesel fuel's ability to ignite. There are many indicators of overall fuel quality such as cleanliness, specific gravity, volatility, viscosity, detergency, corrosion inhibiting abilities, and lubricity. Increasing the cetane number alone is not a fix for poor quality fuel. Additionally, increasing the cetane number beyond the engine's requirements will not increase performance. However, the cetane number of diesel fuel is not always consistent and some customers may desire to use a cetane improver to ensure full performance of their engine. If such an additive is to be used, it must not contain any metal based additives, alcohol or other water emulsifiers.
Poor Lubricity
The 2.0L diesel and the 6.6L Duramax® Diesel engines are designed to operate on today's low sulfur fuel without the use of additives. A fuel additive designed to increase lubricity is not a fix for poor quality or contaminated fuel, but some customers may desire to use a lubricity additive to aid in the longevity of their fuel system components. If such an additive is to be used, it must not contain any metal based additives, alcohol or other water emulsifiers.
Fuel Stability
Fuel Stability and degradation may be a concern for diesel fuels, especially for diesel fuel containing biodiesel. Use of aftermarket stability additives to improve quality of a degraded fuel is not a fix and use of such aftermarket stability additives by customers is discouraged due to concerns of proper mixing and fuel compatibility. However some customers may desire to use a stability additive to increase the shelf life of their fuel. If such an additive is to be used, it must not contain any metal based additives, alcohol or other water emulsifiers.
Fuel Source Issue
If a vehicle is properly maintained but has fuel contamination issues, consider obtaining fuel from a different source. Purchasing fuel from a high volume fuel retailer increases the chance that the fuel is fresh and of good quality.
Parts information
GM ACDelco Diesel Fuel Conditioner
GM Diesel Fuel Conditioner®, P/N 88861698 (in Canada, P/N 88861699) is alcohol free and metal free additive. It is multifunctional additive and provides benefits of cleaning engine deposits, improved lubricity, improved cold temperature fuel flow, reduced fuel filter plugging, corrosion protection, enhanced fuel stability and cetane boost.
GM ACDelco Fuel System Treatment Plus
If the customer experiences concerns related to fuel injector deposits, then it is allowed to use FUEL SYSTEM TREATMENT PLUS® – DIESEL, P/N 88865597 (in Canada, P/N 88865600) based on recommendation from the dealership technician. This is a highly concentrated product and should be used as per defined guidelines.
Edited by newdude
The best option for diesel fuel is to find a station that has a high turn around and large volume seller.  That way the fuel is always fresh.  Here in eastern NC I have never seen a Top Tier Diesel pump.  The Costco here doesn't sell diesel just gasoline.
Same goes true for DEF, get it at a local truck stop at the pump, it is always fresh and stored in underground tanks so it isn't subject to high temps in the summer time.  Plus no containers to have to deal with.
5 hours ago, larryz71 said:
Following.
Used Opti Lube in my 2016 2500HD.  Never had a single issue.
It's all about buying a 'license' to be able to advertise your brand as being Top Tier or Dexos or Dexcool 'certified'.
You'd think it would be as simple as submitting a sample to an independent lab to get tested to prove the quality of your product.  And it should be.  But there's a whole lot more to it than that.
It's just another power and $ grab by certain vehicle manufacturers.  Essentially they're saying "You pay us whatever we think it's worth for you to be able to buy a license from our syndicate to get 'certified' and in return we'll imply to the purchasers of our vehicles, both in the owner manuals, maintenance schedules, and various advertising, that they must use your product or their warranties will be voided."
Other 'non-licensed' brands may be just as good or better, they just chose not to play the old extortion game.  For example, Ford used to recommend BP fuel exclusively, but not anymore.  And at that time, our Ford ran better on Phillips66 gas than it did on BP.  Go figure.  There was talk on here and over on BITOG on how Valvoline (and others) refused to get Dexos-'certified' when GM first came out with the standard, even though their oil met the 'specs', but most of them have since drunk the GM corporate Kool-Aid and gotten themselves 'licensed'.
Back to the OP:  So don't necessarily worry about "Top Tier" fuel.  Buy at a station you trust (not necessarily the cheapest fuel in town) that does a volume business.  If running some additive (some on here running Lucas and AMSoil additives) sometimes makes you feel better, especially after a suspect tank of fuel, go for it.  Enjoy your truck!
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
