What is the flap in the exhaust for? Looks like it opens as it gets hot. My step dad put duels on his 2018 Silverado and he kept the old muffler and pipe.
Good question as related to the Chevy Silverado's. Our BMW X3 & X5 both have duel exhaust with a "flap" that is closed one of the tips during cold starts at idle, then would open after a few minuets or at higher RPM's due to the noise issue. I have modified it to stay open all the time, so am familiar with the "flapper" on them. However, my '17 5.3L only has a single exhaust, so there isn't any 'flap' to delete, that's why I don't understand where the "flap" is on our trucks. Please help explain it to me.
There is a "flapper". It's ahead of the muffler under the truck.
It's sole purpose is to deal with AFM.
Here is what a GM exhaust flapper valve looks like on the inside.  Photo of it closed and open.  Even when fully open, it blocks at least a third of the exhaust pipe diameter !
As stated it’s to prevent the helicopter noise when going in to V4 mode , when I did the muffler delete on my 16 Sierra I took the flap out also.
Thanks.
If you remove the flapper and install an aftermarket dual exhaust system like a Borla system you will get whats called a "drone" sound or what some call "helicopter" sound. That's just another reason I installed a Range AFM delete module in my 14 GMC. No more of the V4 drone for me. Plus saving a little oil consumption and future problems caused by AFM on the engine that they are finding out is happening to some.
I'm not changing my exhaust, but my step dad did on his 2018 5.3l truck. I'm leaving my 2018 6.2l truck exhaust alone ,I definitely don't want that drone sound.
it adds torque to the engine when in v4 mode,  i just bolted mine open with 2 large fender washers and a 3" long 1/4x20 screw and nut, easy it works well, you rotate the flapper, and slide the bolt thru the brackets, and lock it down
Edited by flyingfool
It's for cutting out and throwing in the trash along with the stock muffler. Both of them are really restrictive. I put a magnaflow straight through muffler on my truck and took that valve out and gained fuel mileage and power. I have a completely different exhaust setup now but back when I did the mod my truck picked up 3 mph at my test spot and a couple of mpg. I had already disabled the DOD/AFM on my truck though.
for a daily street truck you kinda want the restriction on the 5.3 motor since it builds torque, the 3mph increase means you made power but power is fuel and not economical for a daily driver. i see all these guys bolting on the 6.2 exhaust system and now the little 5.3 has to rev out, since it lost its factory  torque curve  . And on a 6000lbs truck TOrque is  more valuable to me than HP.. I would keep the factory exhaust just take out the flapper.
otherwise sell your 5.3 truck and buy a 6.2 truck or get the new ugly T1 model with the stroker 6.6L
My boat has exhaust flappers! But for a completely different reason. They're called exhaust shutters. They prevent the back-flow of water into the engine which would result in hydro-lock. Basically water forced into the cylinders if you suddenly stop the boat too quickly. This is a very bad scenario! All kinds of internal damage can happen, as you can imagine. The Mercury I/O engine is a 4.3L GM truck block they adapt for marine use. It's carbureted, not injected and puts out 190 HP.
Just had mine welded open today at the shop. Sounds louder when accelerating, but levels out once your coasting.
I also had the squashed y pipe replaced with a round pipe. Smoother shifting and an increase of a mile or two mpg
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
