I preordered a new winch ready bumper, trying to decide on a winch, been spending too much so I was wondering if you all had any experience with brands other than warn that are good quality but not as expensive. I’d like a 12k synthetic with a wired/wireless remote!
I am an admitted tool snob and firmly believe that you get what you pay for when it comes to tools, so I would recommend WARN or Smittybilt if at all possible.  However, despite being a Harbor Freight brand, the Badlands winch has had some really excellent reviews online and there are plenty of youtube videos out there showing its capability.
I have a Smittybilt on my '05 Jeep Wrangler for over two years now; pulled myself out of a mudhole and helped other folks stuck on the beach or the snow. Great winch, no maintenance issues.
I have an 8k smittybilt on my car trailer, 10k superwinch on the jk, 12k superwinch on my 83 and a superwinch on my 18 year old king quad..lol.  i have never had a problem with any of them. 4 wheeler magazine did an article comparing the badland winch to the rest and it was rated really good..!
Its hard to beat the Harbor Freight Badland winch for the money. You can just bout buy 2 of them for what a Warn or anything else would cost.
I have a Smittybilt X20 10,000 lb winch with synthetic rope on my 2018 Wrangler and it's been a good winch.  It's a wired/wireless winch.
17 hours ago, Z71-K9 said:
What bumper did you buy? Pics?
They haven’t completed the design yet but it’s the winch version of this bumper, gave me $200 off for pre ordering
Please update with pics when you finish!
On 6/29/2020 at 3:43 PM, Unwrntd said:
https://chassisunlimited.com/truck-products/gmc/sierra-1500/19-20-1500.html
You're practically my neighbor lol. I live in Panther Creek. They have a Silverado bumper too, but it's a bit more aggressive.
Small world for sure, I'm on the other side of I-45 in the Oak Ridge area.  That bumper looks really nice, its not nearly as obtrusive as others.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
