Transmission temp
Jcantu2187
  • Replies 52
Top Posters In This Topic
2 minutes ago, flyingfool said:
who ever installed it , did something wrong..
Thats what im thinking i let the sun go down and check it out myself I saw some videos on youtube and it dont look hard.. just got to pick wich one to do since there are different ways to do it
If your transmission did get that hot.  I would change out the fluid.  It pretty much is toast.  Especially since it more than likely isn't a 100% synthetic fluid which most transmission shops use the least expensive fluid that meets the specification.
What’s the max temp for amsoil before it’s shot?
I'd be looking for a kink in the cooler lines if all else checks out okay. There was a TBS on that once upon' a.
There is no specific temperature that I'm aware of.  If using AMSOIL's fluid the same rule applies as if you had the factory fluid.  The only difference is if you did get up high like 240°F you have way better protection since it is 100% synthetic.  AMSOIL did a study with their fluid on taxi cab's in Las Vegas during the heat of the summer out there.  The information is no longer on AMSOIL's site since it is outdated.  I'm sure if you Google it you can find were some other dealer has posted it.  I don't have it on mine because it is outdated.
The AMSOIL transmission fluid, ATL that was in my 2002 Silverado for 100k miles tested fine.  No issues at all and I towed a 4k lb trailer with it and the transmission would get up to 210°F on the interstate in the summer with outside temps at 98°F.
PAO has an oxidation initiation temperature around 250 F. Seals go next and so on. This charts fluid numbers are for mineral oils. By the time you varnish a PAO the seals are in trouble. transmission-fluid-life-.thumb.png.794ac83317a1d9195ed0011c651b32ff.png
Thanks Grumpy. Much appreciated
If the trans cooler return line is hot, it should be flowing pretty good. Would be cool if it wasn’t.
those are about the same temps I was getting with a faulty oem trans thermostat that wouldn’t open and my driver side line was hot and passenger side line was ice cold (ambient)
I should have been more precise. Kinked is not closed, just restricted so to an untrained hand....just saying....it cost nothing to look at all the hoses. Right? Free, simple and all???  :)
i have a feeling the installer forgot to install the pipe plug into the t-stat block... this separates the two lines, cooled and hot side... without the plug , there probably is no flow ..
That would do it! I just flipped the pill doing mine but if he gutted it and didn't plug it...BINGO!! hydro short circuit. :crackup:
Yeah but that line probably wouldnt be hot coming off the trans cooler.
If he had say like 20% or less flow through the cooler, i’d think the velocity would be so slow that it would be very cool.
So i pulled of the t-stat opened it up and no it did not have a plug, the little deal inside was just flipped. I went ahead and tapped into it and placed a plug put the cap on and installed it.. but no luck i drove for a bit and still gets hot
    nolankd
    nolankd
  • Who's Online   4 Members, 0 Anonymous, 440 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
