Whats up guys i drive a 2015 silverado z71 single cab and for some reason the transmission temp is at 24x when pulling my travel trailer.. ive done the thermostat mod and added a transmission cooler to it and it doesnt help a bit.. has anybody had any issues like this
Assuming that the thermostat mod was done right, and the transmission cooler is working probably, maybe trans fluid is already in a bad condition.
Other thought is that cooler capacity is not high enough for your need.
Just assumptions.
Mine rarely pushes 190. What altitude and how much weight?
Well the transmission has been rebuilt due to a bad converter so the transmission fluid should be new but idk what could be the problem.. my travel trailer weight 3,000 lbs  barely feel it when towing it
Feel the passenger side line of the trans cooler.
if it’s ambient temp it means your not getting any, or barely any, flow through the trans cooler
if it’s very hot, just like the drivers side, it means you are getting flow and your trans is messed up.
Ill check it out thanks
whats it run without trailer?
 did you install the bipass plug after you deleted the thermostat?
Were are you getting your reading?  Off the OBD II port?  It might be reading wrong.  Can always check with and IR thermometer.
220 more or less at 100 degree weather
Edited by Jcantu2187
Typo
Reading off the little screen on the cluster
So i drove for a little bit not very far so i just got the temp around 140 or so and checked the line.. well it did feel hot
That is already too much without towing!
And you said yours already have got trans cooler + thermostat mod
If you can, just to double check, find an IR thermometer.  They are not expensive and cool to have to check temps on other things.  Like AC vents and such to make sure it is working well, in the car and at the house.
Yes its got both
Ok ill look for some
    Bigo1112
    Bigo1112
  • Who's Online   5 Members, 1 Anonymous, 874 Guests (See full list)
