.was under my 2018 truck today and noticed the spare is different size the truck came with the 20 in chrome wheels and the spare is 17 in.I called the dealer and asked if this was a mistake and they said no . I would have to buy a 20 in rim. I think this is BS. I think i will put the spare on the rear and let the limited slip eat the differential  up as its under warranty. Anyone have the same problem?
  • Haha 2
Why do you care if the spare tire is not the same size?  The purpose of a spare tire is to get you where you need to go if you get a flat, not to permanently replace a tire.  Very few spare tires are full size tires, most are donuts that you are only suppose to use for 50 miles max.  There is also limited space for most spare tires, which is why they are generally donuts or a smaller wheel size.
Also, if you think putting the spare on and running the tread off it to get it replaced under warranty will get you what you want, you are in for a surprise.  It will not be covered under any warranty and you will be stuck buying a new tire.
No, its not BS Bill.  They are all like this.  The spare is a full size spare tire, and it is NORMAL for the spare to be the wrong size wheel.
The spare tire is a P265/70R17, which is 31.7" in diameter.  The P275/55R20 that is on your truck is the same diameter, 31.7-31.9".  Your differential won't "eat itself up", I promise.  Unless you REALLY have to have a matching spare, there is NO NEED to run out and buy a match.
Edited by newdude
A 31.7" tire at 60 MPH rotates at 636 RPM.  A 31.9" tire would be 632 RPM.  My understanding is the G80 locks up at a difference of 100 RPM.  You're not going to do any damage with such a small difference in tire size.
Ditto as above. Look at your RPO (RC4) or other literature. 17" spare is standard on my '17 LTZ too.
I think he should buy a 20" chrome wheel and hang that under his truck. Then, next spring he can complain about how pitted it is.
  • Haha 1
It’s normal. Go get a 20” wheel and tire if it helps you sleep at night.
I bet you'd be real upset with what they give you in a car lol
its a spare, same tire diameter as the wheels on your truck and thats all that matters
Hijacking thread,
Who has replaced their spare tire? Is it still safe to use? I just happened to take mine off to clean and air up. The Goodyear tire was made sometime in 2013.
3 hours ago, 14LTZ-1LZ said:
Hijacking thread,
Is the rubber cracked? No? Does it hold air? Have you checked? Yes? All good for a spare.
@ Bill.......I would pull it every year & clean it up. The dirt & salts will collect on the groove between the tire & wheel & will corrode the wheel to where it will leak air. My ole '96 did that. I was able to take it to a tire shop that removed the tire, cleaned the wheel & added a sealant to the rim to fix it. A little pre-emptive preventive care will get it to last longer.
Rubber still good no dry rot, yes. Checked it this morning.
get a plug n go kit and an air compressor and keep it in the back. If you get a flat throw a plug in and be on your way in 8 mins. You sound a bit OCD.
    • Yes, and only a couple years before delivery. 🙄
    • So you're saying toss the baby out with the bathwater? @txab posted article was her take on how AI can be used to manipulate pricing as it already does and has been rebuked by the judiciasry in housing. How AI can be and is used to maximize refinery or even Amazon operations all of which are true but because she is who she is; that makes what she says about what is true, false? Is that something akin to Pre-justice aka prejudice?    Look, I'm first in line to approach all information with caution just because we live in a world where people like to lie about someone or something with such a straight face and in such volume that it makes digging to the truth wearisome. Meaning I understand the skepticisms but if I were to toss out everything a person is for a view they hold then my pool of people to draw wisdom from would be non-existent and I'd be forced to reinvent the wheel daily. Not practical.    "Be innocent as a dove but as cautious as a serpent."    Test each word. Every good lie is part truth or no one would believe it. Find the truth in it and reject what isn't.    On this one, AI is being used to do what has been done by hand for hundreds of years already but at such speed, the point of a computer, that it is more easily monetized. This one wasn't that hard a lift.    I wrote a few formulas in a Lotus 123 program decades ago, a series of linked Macros actually, that allowed a daily inventory to be turned into a running P&L and production plan. Something that took three departments a week to assemble now took the time it takes to input the 'daily changes' in inventory. Later that was ungraded to the more powerful Excel program an and integrated with bar code scanning, inventory to supply was done once per shift. It had a huge impact on production scheduling, Seamless interruption flexibility, inventory error reduction, raw materials cost effective utilization and scrap reduction. Huge improvement in the bottom line. I spent months on that and AI could have done it in minutes. So yes, it not only can be used, they would be foolish to not try. The legality, ethics and morality are not the domain of AI. Humans need to keep a reign on it.
    • New to this forum.  Also looking to tune a 6L80 and trying to work out all the issues in my transmission swap.  I have a 6.2 diesel (1983) and have removed the TH-400 and about to put in a 6L80 with a TCM-2600 interface and don't have a clue what I doing after that.  Did you (Leatherneck/RAV3) get your slip resolved? I too hate to spend that kind of money on a tuner that hopefully I will not need too many times although from what steelerdude15 added about the HP Tuner being great for diagnostics would be a plus.  I am also from WNC but below you in Columbus.  Any helo would be greatly appreciated.
    • Sounds like a smart reasonable person with common sense. Bill O’Riley never said he was just a journalist, by the way.
