I did the sure cool STL010 on my 19 5.3 8 speed and my averages  for the last 2 weeks in  80 degree socal weather has been 140f on highway drives and in constant city driving it reaches up to 197f but  I do drive my truck all day for about 6 hours daily.
so out of curiosity I removed the sure cool and did the pill “flip” on the OG thermostat  to see if the results are the same in city driving or lower.
my question to anybody that might know is to check the fluid level with the pill being “flipped” is it still the same procedure and temperature range? For the 8l90’s considering that now theirs a constant immediate flow
also it would be nice if GM released a new T stat at 158f for the 8 speed and called it a day. Their must be a reason why the 6 speed got it lowered.
Your hot check should be at the highest temperature you 'normally' see. The remainder of the procedure is the same.
The 6L80/8L and 10L all use the same thermostat housing. If the housing of the new 158F doesn't have the correct tubing style one can just swap the pill out.
Reasons 1.) The 6 speeds brain is in the oil inside the transmission. Electronics and heat are a bad thing. 2.) Every 18 F over 180 F doubles oxidation rate. Fluid oxidizes faster.
So what were the results. Was the flip lower or the same as the STL010 kit?
Thank you for the response.
and I did the pill flip last night.  so later  today I should have an idea of the results. Same weather and driving style today.  I will post back
Results are in
STL010
average open highwaytemp is 140
Heavy city use  is up to 197f
stays at around 197 if I idle for an extended period
flipped stock thermostat
average open highway is 150f
Heavy city use is up to 176f
Temp goes down to 167 if I idle extended periods.
same constant average load of about 600 pounds of loaded pallets with batteries  in my bed with same routes and stops … All day for about 8 hours of total engine hours. 50/50 city highway.  Average California 90 degree weather.
both tests were done in literally the same circumstances very consistent
2019 Silverado CC Z71 8l90 with 51k miles
transmission has had 3 drain and fills of about 6 quarts each time since purchased new. With blue label Mobil 1 atf. Filter was changed out 1 time at around 20k miles
Front and rear diff are running Amsoil 75w90 since 50k miles.
engine has had Mobil 1 0w30 since new no issues. and recently I’m trying out 5w30 Penzoil ultra. Always changed oil at 5k miles since new.  No DFM disabled lol running it stock.
Edited by 11bravoZ71
  • Like 5
Almost identical to mine for a 90 F day. Amazingly close.
  • Like 4
Food for thought
Some members have observed that the pill flip may lead to unusually cool temperatures for us folk in the butt numbing belt of the country
I'm out of Casper, WY. Last week on my way to Cheyenne (YAY Lowe's and Craftsman), the outside temp was 17 degrees Fahrenheit. Posted transmission fluid temperature as I barreled down I-25 at 80?
90 degrees 🤣
The pill flip works! And HOW hahahaha
I like Grumpy's train of thought. I think I will get a new 6spd thermostat and swap the guts with my factory trans thermostat I have as a spare. When I did the pill flip I got a new thermostat. I'm not sure why.
I could do a little thermodynamic research and see if they changed the 8spd thermostat too. There's a new part number, though it's close to the old 6spd thermostat, so I doubt it.
90 degrees 🤣
You can also blind the grill or upper part of the AC condenser (air to air trans cooler) as an alternative. It was 19 F this morning and mine was in the mid 120's to low 130's. I don't have the second cooler in the condenser like you do. 😉
On 11/22/2021 at 6:25 AM, CadillacLuke24 said:
Food for thought
90 degrees 🤣
A safe alternative for us who live in regions where we see extreme cold is to install GM's newly revised thermostat bypass assembly which now contains a lower temperature thermostat.
Funny you mention that, that is exactly what I did. Trans temp is consistently 130s-150s now. All the time.
On 9/27/2020 at 5:03 PM, 14burrito said:
Little 5 quarts ATF rejuvenation followed with the new ATF thermostat being installed. Curious to see if driveability will change at all and interested to see how ATF temps are altered.
Hello Sir, do you have the part number you ordered? I am looking to do the same thing.
So you kind of have two options now.
1. Pull flip
2. Check your new t-stat housing, if its stamped with a "70" it has a new lower temp 135 stat installed vs the original 180.
21-NA-199 will provide more details. You might be able to get the dealer to cover the cost of a new tstat assembly if you provide them that TB.
Thermostat part number is 13511136 which shows to have maybe been replaced by 86774933.
1. Pull flip
86774933 is the part number of the lower temp thermostat I installed. I believe 13511136 is the part number of the one that comes on the 6L80 transmissions. Don't order that one or you will get the same one you already have...
13511136 was for my 6L80, 2019 Tahoe L83 motor. 86774933 shows to be the successor, did your t-stat housing have a "70" stamped on it by chance?
If you read the TB, they state that the part number did not change and it requires the tech (or end user) to verify there is a "70" stamped in the housing. Whether that has changed or not, I do not know, as the verbiage does not show to have changed within the TB.
Hence why I stated, if one was to order the old tstat housing- they would need to ensure its stamped with a 70. If it is, it has the 135. If it doesn't, it has the 180 and can be used for a pill flip option.
Edited by 14burrito
As far as I can tell in that TSB which is what I went by, the 86774933 just recently came out and is the redesigned product at a lower temperature and was able to be identified by the 70 being stamped into it. My OEM which was the 13511136 definitely didn't have the 70 stamped into it. The 21-NA-299 also confirms that only the 86774933 which is the new part has the 135⁰ thermostat. Only order that one if you want to make sure you get the lower temp thermostat...
Taken from information in the bulletin:
"The new TBV can be identified by the “70” stamped into the bottom of the valve"
Unless a new trans thermostat was installed within the last month or so by dealer, it won't be part #86774933 and won't be stamped with the 70. I imagine the reason for stamping the new housing with the identifiable 70 is for the tech to be able to identify it for reasons of trans fluid service. With the old thermostat, the trans temperature would have to be increased to 180⁰ or so to do the exchange. With this new redesigned thermostat, the transmission temperature would only have to be raised to 135⁰ or so.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,323 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
