Yup, hook it and carry on.
I've said before on here, a local construction company near me gets in new trucks all the time as they have a huge fleet of vehicles. The 2500/3500's will have a goose neck trailer hooked up on first day on the job as a new work vehicle, 200,000 miles later it's replaced with a new truck.
I strongly recommend getting her a few thousand miles before towing.  I do believe it does some good getting things worn in well.  Get your first oil change done, and then still plan on changing out the front and rear diff fluid as well as transfer case fluid at about 10,000 miles.  I for one see that people who take things easy from the beginning with their trucks and break them in slowly and properly tend to have the least amount of issues in the long run.
I picked up my 2500hdAT4 gas on August 15th, so far very pleased with all aspects of the truck. Took about a week to get used to the size and driving characteristics from my 2014 Sierra 1500, but nothing major, parking and narrow roads are fun.
 I took the truck on a long trip Monday 8/31 about 600 miles total to the top of Mt. Washington Auto road and back. It got a respectable 15.5mpg all around. I thought that was fair given going up an 8 mile auto road was steep and coming down I was in low gear. The truck rides good and is very comfortable.
I just got back from towing my travel trailer for the first time, it is light for this truck at 7700lbs fully loaded, so i would say arounf 55-6000 with all of stuff in it. Truck was confident had plenty of power and had awesome grade breaking compared to the 1500. I got around 9.4mpg for the entire trip, which is ok, i saved 10k from getting a diesel so i knew fuel cost were going to be more.
Overall after 1300 miles in about a month I love this truck. Not a lot on the road so it feels unique, gets a bunch of looks and it will be pulling a fifth wheel in the next 18-24 months hopefully. I feel full confident in it's ability, the extra weight and added payload and power are awesome. Like you guys said a mild tune and it will be unbeatable.
Mike
I tend to disagree that mileage is terrible while towing on a cost per mile basis. Between varying fuel cost gaps between diesel and gas, def cost, oil , and filters the difference is narrow. Post emission diesels towing what I tow seem to be getting between 10 and 11 mpg vs. my 9+. Right now diesel and gas prices are more or less a wash but typically that has not been the case. Even with this recent development maintenance and initial price difference makes strong case for gas assuming your towing needs fit in its capability.
The owner's manual says to wait 500 miles before towing, and to change oil before first tow.  This is not under break in, but first paragraph under towing section.
I have 8k travel trailer and load the truck to 9.3 k lbs when traveling.  I just traded a 19 dmax for this 20 Gasser.  It is plenty powerful for me, and more fun to drive than the dmax.
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
