My radio does not come on when using remote start  use the remote start.. has anybody else had this problem?
^^^^As per above?  When using remote start nothing comes on except A/C /heat until you push the start button.
Yes, even if I get in push the brake and turn on the vehicle it is blank.
right and even after I push the start button it still doesn’t come on, I have to turn it off the truck and turn it back on for it to work
The infotainment screen is supposed to come on after you press the break and start button. Mine works everytime.
Maybe there is a setting that is causing this? Have you pressed the power button for the infotainment screen after it doesn't turn on?
I have a 2020 Crew Cab LT Trailboss, everyday driven in normal road conditions. I've had this same problem on separate occasions due to a "bad battery." After remote starting the vehicle, I get in the truck (push brake and ignition button) to turn it "fully on. Engine continues running and all electronics turn on EXCEPT for the infotainment system, which remains a black screen. I have to fully restart the truck to get it to come on.
 I brought my truck back to the dealership  a month after buying it , they fixed this issue by replacing the malfunctioning battery (battery #2).... 6 months later,  it started happening again and the dealership, again, fixed it by replacing the bad battery (battery #3).
Clearly a fresh, fully charged battery fixes the remote start infotainment issue, however, the underlying issue is still present- why am I on my 3rd brand new AGM battery in a 9 month old vehicle? I have not messed with anything on this truck, no aftermarket crap lights or extra electronics anywhere, so what is draining the battery? Do I have a bad alternator?
Any help would be appreciated!
This happen in cold weather?
There is a tech article about parasitic battery draw in temps below 40F -- including diagnostic  test to confirm if that was the source of the issue.
Seems that some have an issue with one of the Seat Memory Control Modules (SMCM) waking up the low speed gm LAN Bus
May or may not be related to the batteries needing replacement.
Intermittent Parasitic Battery Draw Below 40° F/4° C
June 16, 2020
Several intermittent conditions related to a low battery state of charge may be found on some 2018-2019 ATS, CTS, XTS, Corvette; 2018-2020 Envision, LaCrosse, CT6, Escalade, XT5, Equinox, Impala, Malibu, Camaro, Silverado, Suburban, Tahoe, Traverse, Acadia, Sierra, Terrain, Yukon; 2019-2020 XT4, Blazer; and 2020 XT6 models.
The following low battery charge conditions may be present when the ambient air temperature is below 40° F/4° C for an extended period of time:
  • Dead battery/required jump start
  • Slow crank
  • Battery low state of charge and, if equipped, Auto Stop/Start inoperative
  • Instrument cluster backlighting turning on intermittently while the vehicle should be asleep
  • Keyless or passive entry/start inoperative
These conditions are not easily duplicated in the service bay or in temperatures above 40° F/4° C.
These conditions may be due to a low battery state of charge that is being caused by one or more modules waking up the Low Speed GM LAN Bus. When the ambient air temperature is below 40° F/4° C, the Seat Memory Control Module (SMCM) could inadvertently wake up the Low Speed GM LAN Bus. All SMCM’s on a vehicle, including the Driver K40 (Fig. 9), Passenger K40P, Left Rear K40LR and/or Right Rear K40RR module, may apply.
Fig. 9
Begin diagnosis by asking the customer or inspecting the vehicle for any aftermarket equipment. If no aftermarket equipment is installed, try to duplicate the conditions by leaving the vehicle outside overnight in temperatures below 40 F/4 C.
Follow the Battery Electrical Drain/Parasitic Load Test procedure in the appropriate Service Information. If an excessive battery draw is duplicated, as part of the Circuit/System Testing procedure, remove the fuse(s) that powers the SMCM. The SMCM may be powered by more than one fuse. Wait several minutes to see if the vehicle will return to an acceptable battery draw level. If so, replace the appropriate SMCM.
If the battery draw does not return to an acceptable level with the SMCM fuse(s) removed, then continue with the diagnostic procedures in the Service Information.
June 16, 2020
  • Slow crank
Fig. 9
Thanks for posting this, the last battery replacement just happened last week, first week of September. I'm in DC and the temperature has not fallen below 60 degrees since May. It can't be this if it only happens when the temperatures are below 40. I wonder if it can also happen at warm temperatures?
Sounds like the techs are going to have to follow the other diagnostic procedures to determine cause of the abnormally standby draw.
This just started for me yesterday only time it comes on is if I get in and start without remote. Also is your on star button red when you remote start? Have you had a solution to it yet? I have an app on Saturday for mine let’s see what they say
Hello,
       I’m still having the same issue exactly how you explained it is what is still going on for me.. Good luck with your appointment I’m anxious to hear what the diagnostics was.
21 minutes ago, L REY said:
Hello,
Another post said it was a battery going bad so guessing that will be it
    250.3k
    chfkief
    chfkief
  • Who's Online   1 Member, 0 Anonymous, 1,400 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
