49 minutes ago, Boosted16 said:
arent you a mod shouldnt you delete ****** when it gets off topic? youre a bad mod
:rollin:
They also sometimes hand out vacations for foul mouths.
:thumbs:
I'm not just bad at it Boosted, I don't happen to be one.
How funny is that?
:crackup:
14 minutes ago, Grumpy Bear said:
:rollin:
:thumbs:
How funny is that?
:crackup:
thats suuuuper funny man it explains a lot too. That being said the mods are ****ing garbage are they not lol. Wheres my slap on the wrist for cussing on the interent.
Very nice what are your thoughts?
I got one on the work bench at home that I ported the snout myself to work with a Zl1 throttle.  I just haven't had time to install it yet.
contrary to what all the know it alls with stock trucks above say it performs about the same as the l86 manifold from what i can tell on the butt dyno the only noticeable difference is the vacuum it pulls on the boost gauge. Truck still fries tires through 3rd gear
Edited by Boosted16
What throttle body are you running?
l86 87mm. wanted to go with the lt5 but gwatney said porting it wasnt a good idea with boost because the remaining material was so thin
10-4 that was going to be my next question.  When I was porting mine I had to get rid of the stock O-ring.  I'm just going to silicone to ICT adapter to the snout of the intake.
thatll work my man thats what gwatney reccomends you do if you go to a larger tb i know of a guy with the lt2 manifold with a 103 mm tb and a 200 shot of nitrous so they must be able to withstand some torture
Yeah except nitrous doesnt pressurize the manifold or the throttle body, unless there’s a backfire.
ah i see im not really familiar with nitrous but i know plenty of people dont like using plastic manifolds with it while others have no issue at all using them
Edited by Boosted16
reasons
  • 10 months later...
What bolts did you use to bolt you LT2 manifold.  I never installed mine,  then I spun some rod bearings.  So I pulled the motor myself and sent it off to the machine shop.  Now it's got forged daimond pistons 👍.  Since I got it torn apart I'm going to go ahead and install my LT2 manifold.
BUT
I though our L86 bolts are to short so I went to buy LT1 intake manifold bolts and they want 23$ a piece at the stealership.  At 10 bolts that's more than I paid for the intake.🤬
    TopBo
    TopBo
  • Who's Online   1 Member, 0 Anonymous, 3,245 Guests (See full list)
