Okay I stepped into that one.
 :crackup:
Look, guys drive a truck 10 years and put 100 K on it and think that is a high miler and say XYZ did ABC.
Truth is you could have done nothing but top off oil for that distance (before AFM) and got a 100K from it.
Does that mean you shouldn't change your oil?
100K isn't much of a test.
Yet there are guys here than have had oil related failures well under that mark and blame it on the mechanicals.
Some guys get 250K from an automatic with out ever looking at it.
Some can't get 30K from one.
Ya think it's the oil or the load?
A lot of reality to what you said. The not wife at the time bought a truck years ago with 70k on it. Fast forward a few years later to when I met her and there was 275k miles on it. When I asked her about oil changes and stuff she says never has done anything to the transmission and only had the oil changed twice. She said all she would do is check the stick every once in awhile and if it was low she would just dump some in till it got to the top line. That is it. Truck still running today.
I say could be the fluid, or load, or just luck.
Sent from my SM-G975U1 using Tapatalk
On 10/22/2020 at 11:31 PM, 2020_3500HD said:
Grumpy, why the red line over the amsoil?  I am coming up on my 5000 mi get the breakin fluid out change and if you can let me know why?  I have always used Amsoil before but am open to others if it is better for my application by the way I have the 6l90 transmission.  Thanks in advance
Just to be clear, there is no "break in" ATF in the transmission.
The fluid is in there while parts are being used for the first time right???  Hence “break in”.
Better change the brake fluid, antifreeze, rear fluid. Window washer fluid, air in the tires. I hate it when the rubber pieces get caught in the valve stems. All seriousness the transmission as well as the engine has a filter. No need for break in fluid.
I get the engine at 1500mi or whatever (silicone residues from the RTV used for gaskets on the oil pan and front cover).  I get the diffs at 500mi per AAM because of the heat produced from ring and pinion in the first 500mi.
Transmission?  No purpose.  There is nothing to degrade the fluid as there is no RTV used in any point of assembly on these transmissions so no silicone leaching that can aerate the oil.  The filter will catch whatever you can throw at it too.
How about heat? Wear material contamination? That filter is dog and cat catcher, right?
  • Haha 1
I heard the factory throws some clutch material sludge in the pans before they go on. So we gotta get that out ASAP!!!!!
Anybody on this list have experience in industrial drive hydraulics? Automatic transmissions are hydraulics systems. What is the standard for cleanliness and operating temperatures? Tell ya what it isn't. It doesn't boil the control circuits and servos in hot oil and it filters finer than 100 micron (current)/200 micron (screen systems in older transmissions). I'm surprised they last as long as they do. Industrial hydraulics filters to a Beta of 75 in the 2-5 micron range.
Keep it cooled. Keep it well filtered. Keep it changed...it will last awhile.
i got several balers , my big one that runs all day long gets an oil filter once a year, i believe its a 50-100 micron screen. i never changed the oil , but the filter change require a top up of about 1/2 gallon. oil tank is about 25 gallons. operating temp is 90-100 degrees,  full oil change would probably cost $500.  i might top up a balers oil tank every 3-4 years, maybe drain it 6-10 years, but the tanks are huge
best thing one can do to your gm trans, is big trans pan , aux filter or bi-pass filter, tt-stat delete, and GM's new torque management technology, should last 250k miles if all is well
Edited by flyingfool
2 minutes ago, flyingfool said:
i got several balers , my big one that runs all day long gets an oil filter once a year, i believe its a 50-100 micron screen. i never changed the oil , but the filter change require a top up of about 1/2 gallon. oil tank is about 25 gallons. operating temp is 90-100 degrees,  full oil change would probably cost $500.  i might top up a balers oil tank every 3-4 years, maybe drain it 5-6 years, but the tanks are huge
A log splitter is a hydraulic system but not quite the same thing as the 'jewel box" balanced bellows hydraulic speed control on a feed forward Elliot 200,000 hp steam turbine in an ethylene plant. Maybe I should have put industrial in caps.
1 minute ago, flyingfool said:
what's a 'jewel box" balanced bellows hydraulic speed control  ????
It is a very sophisticated swiss style clocked and jeweled hydraulic twin bellows balance speed control system used to control the steam admissions and/or extraction valve(s). Instead of spring or a gas they use fluid. Hydraulic fluid. Nothing pneumatic or mechanical is precise enough nor fast enough.
Compressors this size (186,000 hp.) have multiple critical speeds that need to be navigated rapidly and precisely during a very specific heat up schedule. Then handle abrupt systems upsets during operation. That keeps the 20 square miles around a billion pound a year C2 plant safe enough not to be on an island in the middle of the ocean. The plant I worked in had two of these this size plus three more smaller intersystem cryogenics turbines. At the time they were the largest in the western world. I hear there is one now a bit larger in Texas :crackup:Gave me ulcers (and an adrenaline rush you wouldn't believe) to bring one to speed and there were only two of us trained and qualified to do so. I was my introduction to the Oil/Gas/Chemical field I worked in for 40 years...give or take. At the time a SPPE was a bit more than a Homer Simpson. ?
Your 6L80E isn't quite all that but the principles apply to any hydraulic system.
Keep it cool. Keep it clean. Keep it changed. Keep it inside it's design. Keeps it alive.
  • Thanks 1
got any pictures of the jewel box, i'm curious as to what this machine looks like
Just the ones in my head sir. I have not seen one since about 1979/80. Left light gas for retorting/refining shale oil about that time. They might not even be in use anymore since the age of computers.
I remember the bellows were exposed and under glass. A puff of wind would upset them. The oil was extremely light and water clear. The part you could see was about the size of a coffee table as I recall. It was a long time ago. This HUGE turbine ran a small pump that 'told' the box it's speed via oil pressure. The steam side referenced steam pressure to another small oil system and the oil pressures were compared via the jewel box to a (third) reference pressure that was I over P. The difference was the signal to the admissions valve. I suppose they use stepper motors now.
ummm...You most definitely want to replace Trans fluid on equipment.  just saying!
    Gilkey96
    Gilkey96
  • Who's Online   5 Members, 0 Anonymous, 788 Guests (See full list)
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
