I had my truck lifted about 2 years now and just started noticing a vibration bad. So I did what anyone else would do and jump on google and YouTube. So after replacing my upper control arms and ball joints then my lower as well I still have a shake can someone help I’m at this point desperate
And you've done the normal things like check tire balance and road force on the tires??
Other things to consider on cv axles and driveshafts causing a vibration.
Yes I switched out tires from my Yukon and put them on and same thing I have the vibration check balance on them as well I have replaced upper and lower control arms and ball joints I have a bit of play in the front drive shaft where the yolk is but not to sure if it’s supposed to be like that with a lift
Thanks that is one thing I haven’t done is the rear. Thanks I may mess with it tomorrow hopefully that’s the issue cause this shake is over the top already
Google "Chevy Shake", I have a 2018 Chevrolet Silverado LTZ 4x4 and it happened to me. There is a bulletin out on it for 2014-2018 models. They will start with flushing out the transmission and if that doesn't work then they will work thru to the converter/transmission. They say it could be the fluid used in it. They flushed mine and I've put about 5k on it and haven't had any issues since. If i remember when i get to truck I'll send you the bulletin number.
Thank you I’d appreciate that
Yea bud I go a buddy who just lost a 14 wide on the hwy... I always told him as a good practice swap the hubs once a year or so. He said his didn't even have any play. I told him... Well I told him... And he was approximately 2yr in on his. Just a pic for reference.
Sent from my LM-G820 using Tapatalk
Ain’t much play in front it’s more of the rear now and as I’m driving I look at the tires through the mirror and I see some play like the tire is bouncing
Rear shocks or tire needs a true road force balance. I see this every day here in texas. Which if your in DFW i can recommend the only shop across dfw that was able to balance mine.
I’m in corpus but I will definitely look at the shocks. Could it be possible that they are extended to its max
