Just installed the 5160 rear reservoir shocks and they blow the ranchos outta the park. This thing is planted now. On the fresh compact ice and snow roads and gravel the back end used to dance around to the point of slowing down. Now it’s planted and soaks them up. Can’t wait for my UCAs so I can put the 5100s up front.
1 hour ago, lapoolboy said:
Nevermind....I see you have an AT4.  Are you going to run the fronts at the highest 1.1" setting?
Yup max setting and a new UCA. should just go with the 6112 but I didn’t think the front needed to much help compared to the back. Should give me about a 1/2” of rake
42 minutes ago, Chris Callanan said:
What is the benefit of the 5160s over the regular 5100s?
Added oil. Moving the oil reservoir out gains more room for valving and such in the main shock tube. Was going to go with the 5100s but got a good deal on these
Do you have to replace the UCA on the AT4 with the 5100 at the highest setting?  I have some 5100s ordered but didn’t know I’d have to replace the UCA
I don’t think you would need to with only being 1.1” of list. Most guys are saying they start getting ball joint bind at 2” of lift. I’m probably going to go higher at some point or add a spacer  depending on tire size so I figured I would put a UCA in now
a monotube or a twin tube shock is not completely full of oil. It has a head space. Head space allows the oil to froth. Even if it is under N2 pressure. Froth does not meter the same as oil when passing back and forth past the piston and valve shims. The shock fades.
A reservoir shock allows the tube to be filled completely. The reservoir itself has a piston in it that separates the oil from the head space. The head space is under N2 pressure to prevent foaming.
On 11/21/2020 at 2:02 PM, AdamAT4 said:
are the front lift struts available yet?
I'll get getting the Ready Lift UCA and hoping to use Bilstiens to get an extra .75 to 1" lift.
Front 5100 struts are available and give 1” of lift. I see also that the 6112 are available now as well  and have an eibach spring but still require assembly
does anyone know if the Bilstein shocks affect load capacity of the truck? If anything I'd think that 5160's with the extra oil capacity would help dampen the load better, but maybe not increase capacity.
Shocks have nothing to do with load capacity.  The weight of the vehicle and its load is carried by the springs.
  • Like 4
I just installed the 5160's in rear and 6112's in the front today. Amazing! I didn't know they were using Eibach springs. Where did you find that info? That's huge plus if true.
What ring positions did you use for the 6112's up front? I'm assuming the kit came with new springs? Where did you buy it from? I'm looking to do the same on my 2020 TrailBoss, but retain the stock height and wheels.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • That computer lies!
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
