1 minute ago, BossTaco2020 said:
What ring positions did you use for the 6112's up front? I'm assuming the kit came with new springs? Where did you buy it from? I'm looking to do the same on my 2020 TrailBoss, but retain the stock height and wheels.
I went with #2 position. It's about a 1/2" lift. Perfect! Don't have to add UCA's or worry about angles. Definitely leveled a bit and feels much more planted. Exactly what I wanted. This is what this truck should come with from the factory.
  • Thanks 1
Here's where I got'em.
https://www.shockwarehouse.com/site/product.cfm/id/3201223/name/Bilstein-47-309524-Front-B8-6112-Suspension-Kit-Chevrolet-Silverado-1500,-GMC-Sierra-1500
So Bilstein directly told me that their front shocks will only raise an AT4 1" as they are already lifted 2" from factory fyi for those looking to level. Truck will still be raked
This is set to position 2. Looks pretty good to me. Maybe your At4 is different. I am on my driveway. So it's probably perched a little. I think all trucks sit and rake a little different.
Looks fantastic! What size tires do you have in there?
  • 9 months later...
On 11/20/2020 at 9:55 AM, Grumpy Bear said:
a monotube or a twin tube shock is not completely full of oil. It has a head space. Head space allows the oil to froth. Even if it is under N2 pressure. Froth does not meter the same as oil when passing back and forth past the piston and valve shims. The shock fades.
A reservoir shock allows the tube to be filled completely. The reservoir itself has a piston in it that separates the oil from the head space. The head space is under N2 pressure to prevent foaming.
1) What BIL part # were your 5160s; I'm seeing several part #s for my 2021 Silverado.
I run King shocks. I was a generic response to TYPE not brand. Sorry to confuse you.
Not only is Grumpy not using Bilstein socks, but he also doesn't have a T1xx truck.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
