I have a 2019 TrailBoss and brought my truck to dealer other day because last couple of times I have filled my truck up it does not read full.  I have had 5 silverados and fill them up once a week and never had this issue and I am ocd about clicking them several times to make sure it is full.  Took it to the dealer and said they scanned it and no codes popped up.  Filled it up yesterday and here is a pic of the gauge.  Anyone else ever have this happen or suggestions to dealer what to look for?
There will be diagnostic information available to the dealers technician to test that the sender in the tank and the gauge in the dash.
You shouldn't have to tell them anything other than the symptoms.
Did you fill it up at the same gas station each time it read low? Could the pump be shutting off prematurely? Maybe try another gas station and see if still happens.
How close is the dealership to you and a gas station? Maybe you could ask to have a tech go with you to fill it up so he can verify the issue.
Just throwing out some thoughts.
No expertise implied or expressed
I have tried other gas stations and same result.  This is ridiculous.  The amount of money you pay for a new truck and two years old and gas gauge does not read correctly.  I offered to take tech to gas station and said they did not have time.
Picture shows it has 24,000 miles, so if it's two years from new purchase it's still under 3/36,000 bumper to bumper.
Failures happen, it's how dealer handles it that is important.
What are they proposing for the next step in diagnosis/repair?
i would just call them to make a appt to drop it off so they can diagnose and repair the Under Warranty fuel gage not registering correctly issue previously brought in for . ask them when is a good time for them to have a Loaner truck ready for you to use until they get your Truck issue solved.
This will nicely put them on the spot ,Letting them know its there issue without being to aggressive. if they refuse then call GM for help.
this showing wrong would be drive me beyond my ability to function
Nice and polite but firm works better then a shouting match
Good Luck.
  • 1 year later...
I have seen this problem on other trucks and it is caused by a poor ground connection at the fuel level sensor. This sensor is difficult to see, get at and test. The tank needs to be dropped down or removed to get at the sender. This procedure is more difficult with a full tank of gas. This fault may not set a code. I am sure your dealer does not want to drop the fuel tank just to "take a peek" without verifying the complaint.
My advice to you and Silverado2021 would be to take a photo of the fuel gauge after you have filled it up, take it to the dealer and describe this fault in detail. Be polite but firm when you explain that this truck is under warranty, has a small fuel tank (24 gallons} and you need to get this fixed ASAP. It may be possible to plug in a new fuel sender to the existing vehicle wiring using a known good external ground and slowly "sweep" the sender from empty to full
 to test the gauge in the dash and truck wiring. After the tank is removed it would make a lot of sense to replace the sender because of the labor time involved.
If your dealer will not attempt to repair this problem under warranty have them give you the contact for Chevrolet Customer Service. Chevy should take care of you.
Agree wit Bikerjon here. My 2019 has never shown this symptom. I can let any gas pump click (auto shut off) once, and my gauge will show the tank is on full.
The dealer should perform a gauge sweep with GDS to make sure the cluster is good. They can make all the gauges go from full to empty..If it checks out then time to check the level sensor in the tank.
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
