So installed the pulsar LT on my 19 6.2L 10 Speed and I'm either confused or happy.  Adjusted the tire size to get the speedometer corrected.  Still a bit off from GPS, but not by much.  Original tires were 275/50/R22 which translates to 32.83 inches, now running 37 inch tires.  Only about 1 or 2 mphs off throughout the entire range, which I believe is acceptable.
Secondly decided to disable DFM out of curiosity more than anything.  Some things I noticed:
  • I have an AFE cat back exhaust:
    • The Suburu drone is gone!
  • When configuring:
    • Electronic step rails went crazy
      • In/Out randomly and including full extension (for bed access assistance)
      • Went away after starting vehicle.
  • The MPG is reporting better than with DFM enabled:
    • Like 5 MPG better in the 50 mile sample.
      • Going to need to get a full tank and take the mileage to verify on paper.
Anybody else get better MPG with DFM disabled?  Or is it lying to me?
EDIT: MPG has normalized.  Getting 11-13 mpg local, 15-18 mpg highway.
Edited by clowe1243
Update
I've been using the Pulsar for about a month now and I'm loving it. I'm seeing about a 1.5 mpg loss but I'm also working through some issues with my Rotofab install. I am seeing my mpg go back up and we'll see if I get into the positive number. I have a Magnaflow catback exhaust and the the drone is gone.
Not even close to representive data, report back an average after 6 tank fills.
I just want to know if you could swap the muffler from them and get near the same results.  1400 is a bit steep
https://afepower.com/afe-power-49c44114-apollo-gt-series-3-409-stainless-steel-muffler-upgrade
The key is getting rid of that flapper.  I'd imagine it can't get any worse.  Cant even tune the 6.2L at a reasonable price atm.  Ive seen some guys that just lock the flapper open.  Make it sound tons better, but without disabling the dfm...your still gonna sound like a suburu.
Your MPG is "showing" better because your speedometer is correct now.  The truck didn't think you were driving as far before.  Also, you can get your speedometer dead on accurate.  The second number in the programming is 10ths of an inch.
-Eli
Edited by Tjeli
I might cut the flapper first and then do the muffler
Whats going on with the roto fab
I didn't torque down the hose clamps. Hose popped out after a 100 miles and my truck throw a code.
The Suburu drone is gone! ?  yeah, can't explain it. I'm running 2 borla's in line and was still loud. So quiet now, why??  My running boards also spazzed out, all good. Only issue now is drivers side mirror keeps lighting up ghost vehicle alert.  maybe truck bug, not pulsar?
New weirdness.  My drivers side left floorboard stays open until the truck internally times out, or I start driving above 3 MPH.
  • 3 months later...
on mine almost the same but it was my filter i got the corsa intake came of and thew a code now it wont respond the same on the level 5 even with the new filter on i don’t know if it messed up my pulsar lt or what
On my trailboss custom 6.2 I ended up never getting it where I liked it. Throttle sensitivity when I plaid with that made the upper gears shirt funny. And when I disabled dfm it also disabled decel fuel cutoff when I let off the throttle when scanning the truck. Plus truck had onstar issues unless I enabled dfm. So for me I wasn’t happy enough to keep it. Just my 2 cents.
So what I’m hearing is the Pulsar is an overpriced “investment” that may or may not make a DFM truck run better, but there’s a high chance of computer glitches.
It’s bad enough that the guys at Range Technology won’t even make us a simple DFM disable (6.2 10-speed), but instead they release our only option - the Pulsar LT. However, it’s way more expensive AND not even reliable.
Such BS.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
