I got told my throttle body in my 2017 is failing and throwing codes. Has anyone upgraded throttle body on a stock truck? Any good options out there to fix it and maybe get alittle more "juice" out of their truck?
Anything helps thanks!!
If youve got an L83 you could upgrade to the l86 tb and im i did this before putting my turbo on and saw noticeable performance especially im bottom end and throttle response but if youve already got an L86 youre only other gm option is the LT5 tb which requires an adapter plate to be installed. If youve still got the l83 intake manifold i doubt youll see any major improvements in performance until you upgrade to at least the l86 im. Any of these will require an adjustment to your tune too btw.
I got a Soler Performance TB on my L86 and I thought it added a nice improvement from stock.
The biggest they have is a 95mm which is equivalent to the LT5 throttle body. I assume you wouldnt buy an 87mm because thats what comes on the l86.
Soler performance 95mm=$335
Gm ac delco 95mm=$195
I did this one:
SE8223-040, 87 MM (91 MM EFF.) - $275 now, I think I got a discount/sale price. Don't recall.
20 minutes ago, ftwhite said:
I did this one:
For that price he could just get the lt5 tb tho thats what id recommend it would be a gain of 3/8” from stock as opposed to 3/16” with the 91
$195 for a LT5 TB + $70 for the adapter plate to fit a L86 intake? Yeah, that saves some money, I guess.
Assuming he is starting with the L86 intake, or upgrading to one, at least.
I'll have to add headers and CAI on mine first (coming) before getting my brain wrapped on 95mm vs 91mm.
without a doubt too close to make a big fuss over i would literally go with whichever is cheaper honestly. If hes putting it on an l83 either one would provide noticable improvement
bigger is better, since the factory tb programming wont open them past 80-84% at WOT unless you got the 6.2 software or 6.2 equipt truck.
Edited by flyingfool
I think this is only true if you're making more power than the factory driver demand tables can accommodate. For example, if I'm making 100 HP more than stock thanks to a blower, the higher pedal position rows will become a limiting factor.
That's all TQ MGMT is these days. Log TQ MGMT advance and it will tell you more about what's going on. (ignore TMA - tq mgmt advance - during shifts as that's there to make the shift smoother and faster.
8 hours ago, flyingfool said:
I'll look into that. but at stock power my last log showed 84% tb opening
For whatever reason there's a half dozen different PIDs related to pedal position and throttle position. I seem to remember reading about one of them that always displays 84%.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
    • Don't need the air tube but that's how everyone sells them. Most places won't remove that one piece and sell it alone. No money to be made. Hoping someone swapped theirs out for a CAI and no longer wants it. Not asking anyone to give it away. Offering to buy it but I don't need the tube. It's held on by a hex head screw and nut. Been all over eBay.
    • Wait, you guys are changing your oil???
    • If you need that mount looking piece.  You need the air tube.       Cheapest one I see on eBay - 2007-2014 GM Silverado 1500 Air Cleaner Outlet Duct Assembly 5.3L OEM 15901934 | eBay     Same price but free shipping - 2009-2014 CADILLAC ESCALADE 6.2L AIR CLEANER OUTLET DUCT ASSEMBLY 15901934 OEM | eBay
