Since GM didn't offer the RSE (rear seat entertainment) for the 19+ trucks, has anyone found a way to add video to factory screen?  I am been talking with the guys at MVI (gm-navigation.com) about using the front camera option, which would allow me to come out of the module with an HDMI, but am unsure.  It isn't a desired function and I have a few concerns.  I want my passengers to be able to watch video (either adding a blu-ray player or screen mirror from a phone).
Seems pricey.  I was hoping for something that would integrate into the factory stereo, similar to the previous body style.  We also wanted the video to be viewable from the front seats (passenger, etc.).
Same setup here for 500 less
https://www.shopchevyparts.com/electronics/2020-silverado-1500-rear-seat-infotainment-system-with-dvd-player-black-vinyl/84556195-p-92305781.html
I still cannot see that on the front screen.  I’m looking for something that will play video on the front screen.
3 hours ago, lapoolboy said:
Don't bother....the resolution is garbage.
Resolution is probably 720.  It better than DVD quality and should show a blu-ray just fine seeing as it’s only 8”.
I have an Mvi system on my 18 Sierra.  My picture is great for dvd,  firestick, and cameras.
Yes, I had their system in my ‘15 Sierra and we have one in our ‘19 Tahoe, but nothing for the new Infotainment system.
They were telling me about a front camera option that has an HDMI input but their site has been down for a few days.
Not to be a downer, but if you figure this out you better remember to turn it off if you get pulled over. There is a reason that auto manufactures lock this out on the front screen.
Agreed.... this is as bad if not worse than fumbling around on your phone in many areas.  Generally around 250 bucks
As a biker, I also cringe at this
Do you ever drive over the posted speed limit?  Because you get a ticket for that too.
I've actually had front seat video capability in my vehicles for the past 20+ years...since I had my 2nd car when I was 18.  I'm pretty versed on the laws and what I have to do if I get pulled over.
Sure do, doesn't make it right.
Video playing on a screen, ie distracted driving, is more dangerous than speeding.
Just the opposite for me.  I've had front seat video capability in every vehicles I've owned for the past 20 years.  I tend to speed and change lanes alot, but throw on a video and it calms me down.  I don't really watch it as much as I do listen.  Not sure why, but its different than plain music.
Just the opposite for me.  I would say I am less distracted with a video playing.  I tend to speed and change lanes alot, but throw on a video and it calms me down.  I don't really watch it as much as I do listen.  Not sure why, but its different than plain music.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
