Just curious now that the brand new models come factory w wireless CarPlay ... have we found a way to upgrade older year models? Like they did w navigation and CarPlay and android auto in trucks without by changing stereo modules?
ive got a top level slt version w all the stereo options... I know wireless CarPlay works off a mix of WiFi and Bluetooth...and my system has both modules....
any help on this matter would be greatly appreciated
Edited by Sickness1972
I ordered the carplay2air should be here this week. Will update you once I have it up and running
I’m interested to hear how those work but I wonder if we can just replace a module in the system from a brand new truck, into mine and make it work...
I know folks have done this in other trucks .. with navigation ... or with wired CarPlay so I am sure it has to be able to be done
Not possible from a factory retrofit standpoint. All new hardware and communication bus.
@pgamboa who do you suggest for a complete upgrade... I have seen you post about a aftermarket company that has all the integrations ...
I also read somewhere that Pioneer is soon to be releasing a specific plug and play receiver for these GM’s built off there NEX entertainment lineup package... but I have no idea if they went thru w it, if it’s still happening and if it is, when it will be released
Wireless just came out for the T1 new body 2021, which have all new and different radios, modules and radio operating systems compared to K2 trucks 2014-2018.
There is a device in the aftermarket available:  CPLAY2air wireless adapter for factory CarPlay – CPLAY2air.com
I have the CPLAY2air in my truck and so far works very well. I tried it in my wife's Honda and it  worked well there also. Its about the size of a business card and i leave it in the center console and my phone stays in my pocket. I am going to order another one for my wife.
  • Like 3
Does this work with Android Auto or Carplay only?
I bought that (CPLAY2air) and I was unimpressed.
Too long of a boot time and my audio was degraded as well as response time.
Otherwise, it  well ... just worked.
I wasn't happy, I stayed with plugging the iPhone in.
Has there been an update recently?
Edited by MikeBMW
Spelling
  • Thanks 1
Was the audio worse then just using Bluetooth?
I just received the carplay2air unit Friday. After using it all weekend I have not noticed any music issues- it works great. Simple set up
i modified the armrest for wireless charging with an Apple MagSafe charger set the phone there and it automatically connects to the truck and brings up CarPlay. Have not noticed any lag etc.
Edited by Sean006
Yes, the audio seemed degraded.
Great information and feed back, thanks!
I'll give the device another try.
Much appreciated! :)
Edited by MikeBMW
Had a chance to check mine, tested boot time 25 seconds from engine start to carplay on screen. Audio quality I am not a good judge, but swapping between cable and device I cannot tell any difference. No lag that I notice. It is a crazy price for a usb dongle, but for  the short hops that I usually drive it is very convenient. Checked my firmware version     ver:2020.11.10.2137
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
