For those with the multipro tailgate, has anyone sprayed their tailgate? I like to err on the side of engineers being smart and doing things for a reason...trying to understand why it isn’t sprayed and just a plastic cover protector
that plastic cover is the tailgate am pretty sure, not sure there is sheet metal underneath.......my 2500 didnt have plastic it just had sheet metal......and believe my 19 RST just had the plastic cover with no sheet metal under it.....am not 100% positive but remember either reading it or hearing it......could be 100% BS of course
which is actually nice cuz replacements arent expensive and can be eaily done if it gets messed up and mine surely will
Edited by Dunn
When I had my bed sprayed with linex they told me there was only a skeleton under the plastic and did not recommend spraying the tailgate
Edited by Greyhound6.2
Mine was sprayed with a bed liner from the factory. (Bed and multipro tailgate)
You should check your tailgate again, it's a plastic cover, not bedlined. It matches the look, but it is a plastic cover. I have the factory bedliner and multi flex tailgate I ordered from the factory.
You can probably use the DIY roll on or spray on bed liner. The heat the pros use would more than likely damage the plastic
    ncleg
    ncleg
  • Who's Online   6 Members, 0 Anonymous, 757 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
