I have a 2019 SLT without the NHT/Max Tow, but with the Z82 trailering package, factory trailer brake controller, trailering app, and the IOT radio.  The truck did not come with the trailer TPMS; not only did it not come with the sensor, but it also didn't come with the module that goes behind the rear license plate.  Not realizing that a separate module was needed, I ordered the sensors first.  That obviously did nothing, as the truck did not recognize them.  So I then ordered the module from eBay.  My truck had the wiring harness already ran to module location, so when the module arrived I just plugged it in.  The trailering app immediately recognized the module and gave me an option to set up the trailer TPMS sensors.  No dealer programming necessary.  It was all plug and play.  I had America's Tire install the sensors, and I then used my TPMS tool (Amazon, same one for doing tire rotations) to program them.  It works perfectly.  The trailering app now displays the tire pressure and temperature for all 4 trailer tires.
Just thought I'd put this out there in case anyone is wondering if this can be added.  I read a GM tech article where the writer indicated that it could NOT be added after-the-fact, but that is clearly not the case.
Here were the items I purchased to make it all work:
  • Sensors, part #84152501.  $65 new on eBay for a set of 4.
  • Module, part #84458180.  $77 new from GMPartsDirect.com
All-in for about $150.
  • Like 7
You have a picture of the installed module? Can one see it by taking the rear plate off?
Sorry I don’t have my truck at the moment. But if you take off your rear license plate, you can quickly and easily tell them if you have the module or not. If you want to post a picture of yours, I can tell you.
Not my picture, but one I found online. The module is the rectangular box on the right, that says MADE IN UK and SCHRADER ELECTRONICS.
Thanks for taking the time.
Thanks, guess I should have hit refresh before posting!
Thanks for the info!
Sent from my Pixel 4 XL using Tapatalk
I have a '19 3500 Denali. It has the Z82 trailering package, factory brake controller, 5th wheel prep, but a different radio (I06) and RPO JK1 - TPMS Delete. I looked at the back of the truck and did not see an additional wiring harness. So in addition to the module I'm guessing I'll need that harness too. Any input is appreciated.
So right now my trailer app in the truck only gives me the option for the light check. If i get the module and tpms sensors, then i'll have the availbilty to monitor the trailer tires? I thought that the software in the truck was different to be able to have that ability...could be because I have an RST without the advanced trailering package?
I also have an RST and all I get on the trailer app is a light test.  I decided to just try adding the module to see what would happen.  I still just get the light test.  To the OP, prior to adding the module did you only get a light test option or did it give you other options?  I'm curious because I had trouble getting the plug into the module (thought it should have been easy) and I want to be sure I didn't mess up the harness in the process.
I'm interested in this too. I have an LT with the larger radio (Sirius XM, HD radio, etc), but my trailer setup only includes the light test.
I checked and I don't have the module, it sounds like it takes more than just buying the module, maybe a flash from the dealer?
  • 6 months later...
good afternoon
I have a 2020 Silverado 1500 LT trail boss that does not have the advanced trailering package
I purchased the module you recommended above when I plugged it in in the rear of the truck behind the license plate and turned the truck on it did not recognize it nor when I plugged in my trailer
I believe I have the iOS radio .  Is there anything I need to do to get this to work?  Any type of computer flash in the OBD-II?
we are leaving on a camping trip in two weeks so I was hoping to have this done soon anyway advice would be much appreciated
Hi SoxFan904... Did you figure out why it didn't work, I have a 2020 RST with the IOS radio and Z82 trailer pack. Would like to try it as well but don't want to spend the money if it doesn't work. Perhaps a GM dealer can program the module? Any info you can provide is appreciated. Thanks.
I have the Z82  in my Codes but I was not able to figure it out.  I installed the module I bought in the back of the truck and it did nothing, even when I hooked up to my Camper.  My Truck ONLY has the trailering app.  I am going on a trip soon with my camper, so I didn't want to take the chance of having the valve stems replaced with the GM ones I bought and have it still not work.
My understanding is that it was something available from the factory and cannot be programmed, but I cannot find a definitive answer on that.  I was hoping it could be an "upgrade" I could buy.  I contacted my dealership and they were unsure as well.    I'll provide any updates if I have them, as I am going to try again to reinstall it and maybe have a valve put on my spare tire as a test.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
