Hey how’s it going Chevy crew. I have a 2021 Chevy Silverado trailboss 6.2. I just did a resonator delete and installed a flow master 40 series. Does this void my warranty in any way? What’s been your experience? Thanks.
It sounds like a 6.2 engine should sound. I was just debating if I should buy the borla GM cat back exhaust they sell for like $1700 or install flow master and resonator delete for $300
Good morning,
Nah, you didn't void your warranty in any way. Per the law(Magnuson Moss Act), modifications made to the vehicle that affected said items would be excluded from warranty coverage if an issue arose, or if they were found to have created/caused another issue. Example, since you changed your exhaust a bit, say you had an issue with something related to it, they could push back and fault you. But, say your transmission acts up some time later, it's still covered because that's unrelated to the exhaust. Not the best examples, but hopefully it paints the picture. It seems the only time folks really void majority of their warranty is when they tune a vehicle, otherwise it's just item by item with aftermarket mods if issues come up.
Sent from my SM-G965U1 using Tapatalk
Obviously, really bad info.
If for some reason the engine were to run lean and eat a pistion or 2 that would be on the OPs dime.
I'm looking at it more as if it were from the muffler on back and no upstream sensors were affected, then any issue such as what you stated would be hard for the warranty to be denied. Sure, if a full exhaust system were swapped, O2 sensors altered, cats removed/replaced, then absolutely. But per the way the act reads, not for what he did in my opinion. A simple muffler swap shouldn't cause any issue such as that and if it did, I know I personally would go to hell and back before that were from my dime.
Will it cause you any warranty issues if something happens to your truck? Probably not.
But that's a larger "probably" risk, IMO. Dealers are getting more and more stingy about stuff like this. They very well could make a case that your aftermarket exhaust caused some mechanical malfunction. Sure, you could go after them and waste 6 months of your life and spending lots of $ (and opportunity cost $) to prove them wrong.
It's all up to you, OP. I bought the GM catback because I didn't want any chance of this kind of circus show with my local dealer (who have already show they would pull something like this).
If my truck were out of the powertrain warranty, or close to it, I would not have cared and put a cheaper exhaust on it.
Would a flow master muffler and resonator delete make engine run leaner?
Mine didn't, and it shouldn't. I removed my muffler and flapper valves and put on a Flowmaster Super 44. I put about 1k miles on it before I reverted back to stock just because I wasn't a fan of the drone and hearing the DFM.
I guess I need to throw on a disclaimer before I'm hit with giving "bad" info again. As some others said, there's always a risk when modding and you have to "pay to play" some times. But, what you're doing is a very common set up with what seems to be very little or no problems.
Just put some Duratracs on.. you won't hear it over the drone of the tires :)
Its all sound.  That's all you are really changing is just sound.
If you were doing catted long tube headers?  That would require a touch of tuning to take advantage of the added airflow.
Edited by newdude
Just put some Duratracs on.. you won't hear it over the drone of the tires [emoji4]
Hahaha, if only this thread had happened a couple weeks ago, [emoji1787]
I am only aware of it as my buddy has a Trailboss himself and has a 40 series.  Says he can't hear the exhaust over the tires and I'd be inclined to believe it.  They are not quiet :)
You should hear the territory MT tires on the AT4 carbonpro. I wonder if I replace just the muffler with a borla attak and keep everything else on the exhaust stock,  will I hear it over the tires?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
