Found part # for the new AT4 high clearance step for RPO code VXW or PDG....GM 84630474. Kind of expensive so I’ll have to wait for a used set.
Edited by EXSlider400
Following -- I want to switch out the 6" oval steps that came on my 2020 AT4. The high clearance steps weren't available yet.
I have the Chevrolet version of these on my trail boss. I love them a lot. I was able to score a set used off of an HD a few months ago for cheap. So far they are awesome compared to the other off road steps and the flats on my fathers Silverado. The finish is fantastic.
Dang these are what I was wanting for my AT4 but ended up finding a set of Westin HDX for 125$ so I could not pass that deal up. They hang down a little lower then I would like but are not bad.
I really want a set of these, they are one of the best looking options, but we've seen a few reports of guys denting the rocker panels on facebook, evidently it's extremely thin/weak on these trucks, and the high and tight running board encourages shoes/boots to hit it harder/more often   Couple guys installed the Bushwacker rocker panel covers to help with the issue.
Thank you. Good helpful comment which is what these forums are for. I wish more would do the same instead of just ignorantly talk $h!t. 👍🏻
I have a set for sale 530-515-8285
26 minutes ago, waterman said:
Pain in the butt to clean. The step and the paint near it.
Can you post pics of yours?
What have you used or done to clean them?
-Grover67
-Grover67
My setup is from the factory. The steps have a coating similar to bedliner, they trap dirt continuously. If you get dirt behind them, it is difficult to remove.
On 6/1/2021 at 4:21 PM, Silverflash22 said:
I have a set for sale as well in Michigan.
Hi Silverflash22, new to the board here and a new AT4 owner as well.  On the hunt for a set of these steps and may be interested in the set you have for sale, but am unable to send a direct message on here for some reason (likely because I just registered).  Can you shoot me an email at [email protected]?  Thank you.
Where about in Michigan and price?  I’m also in Michigan and debating on getting a set.
    250.3k
    Tiffanyrose
    Tiffanyrose
  • Who's Online   4 Members, 0 Anonymous, 964 Guests (See full list)
    • It seems fine because it pulls everything out of a hot engine. I’m not going to worry about a thimble full with 5K oil changes with synthetic oil. Every other oil change is at Honda they pull the plug. I watch them through the process. It turns out going to Honda what amounts to their normal oil change intervals.
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
