Ok, here's one more 3.0 Duramax with the no-start problem; '21 Sierra 1500. It happened twice within the first two days of ownership, four times total to date. I've owned it six weeks, 2,600 miles on the clock. Always seems to happen after it's been run, then stopped for a few minutes, then an attempted re-start. Never on an auto-stop/start. I really hate the idea of having my new $60k truck being completely torn apart. I can't imagine that it would ever be quite as tight and quiet as it is now. Crap.
I can't imagine how much GM is going to have to spend to fix this problem, if in fact the cabs have to be removed. I'd love to know how many problem vehicles have gone out the door.
I have a 2021 sierra 1500 elevation. Odomoter just hit 1000 miles and ilI had this issue for the first time today. Went in to press the ignition and it just cranked for about 30 seconds. Then started right up the next time. Have an appoinment later this week to add some power running boards and will mention this alongside some window trim issue.
Hey everyone. I have an update. Just went to leave work today and just had the issue happen again after trigger wheel fix. 3 strikes your out. Called my dealer and getting a new truck Wednesday. Hope they find a fix that doesn’t involve tearing the entire truck apart to not fix the problem.
  • Sad 1
New truck?  Mine is in for the second time… please let me know about getting the new truck?  Thanks Bob
Yeah mine has been in 3 times. I posted a while back and been updating several times. Lost it on GM and the dealer and now I’m getting a new truck with from lemon law.
Got it, thanks...
On 3/23/2021 at 5:52 PM, Dbersuch said:
Bought a 2021 Sierra with the 3.0 last week. Twice when trying to start the truck the starter engages and cranks the engine but it will not fire. Starter times out after a few seconds and stops cranking. Anyone else have this happen? 570 miles on the truck.
I have the exact same problem. GM is aware of it. Mine is caused by a bent camshaft sensor and apparently requires the cab of the truck to be lifted to gain access to the camshaft cover and sending. The service writer is telling me it is about a 40+ hour job. I have the TSB on it, let me see how upload it.
#1 You don’t have a bent camshaft sensor.
#2. Did you not read the responses on this thread? That TSB was done on one of the members trucks a few posts up that’s responding in this thread and it did not fix his problem, why would you allow them to do it?
So my third one happened today at 1700 miles.  Call GM customer service just to see if they had any info on this issue.  What a waste of time.  Said they could find nothing.  With  Gruggas having it happen again and another truck with the issue but no bent trigger I’m feeling a bit deflated on this.  I wish it was happening enough to have the dealers catch it.
On 6/4/2021 at 11:45 AM, Gruggas said:
Hey guys I have an update! So dealership finally got everything dialed in. Apparently mine was the first one to find the fix. I have the pictures of the bent timing ring for the camshaft. It’s a pretty big job. Involves removing cab, changing timing gears and chain on top of the ring. I suggest anyone having this issue contact your dealer immediately. If the bent ring is bent enough, it can touch the timing chain causing damage to the chain. Truck runs beautifully for now! Will keep updated in maybe a months time to let you fellas know how it’s going.
Did they say what might have caused this to happen, just replacing parts does not fix the problem?
Same thing happened to me. Brand new traveling from Arkansas to Florida and stopped at a gas station. Tried to start and it kept trying to crank but never started which eventually timed out. Tried again and it fired right back up. I then had this happen again when I went from our house to a store. So the first time the engine has been running for a while but the second time it wasn't.
Took to the dealer when I got back and they did some computer updates on it. I see people talking about this all over the place but everyone has a different answer.
This article points to bulletin #20-NA-218 (https://www.gm-trucks.com/tsb-issued-for-no-start-long-crank-condition-occurring-on-trucks-suvs/) that talks about reprogramming the ECM which is what my dealer did.
Edited by Jacob D
That reprogram was their first attempt at fixing it earlier this year. It didn’t work and either has this super invasive procedure for replacing the Cam Exciter wheel that came out in May. Now they are saying to check the cam sensor for metal on the magnet, that doesn’t make sense either since the member here who had the 40 hour repair had both sensors replaced and it still did it. They have no clue how to fix it yet. On the GM Facebook pages there are 3-5 new owners reporting this problem every single day, it’s widespread.
Edited by ColoradoCub
Great.... well I tried to reach out to GM directly basically to complain about it and complain about GM not putting out any info since so many people online are complaining about this same problem. We will see if their "specialist" ever call me back.
Do you have anything I can provide the dealer from GM stating this is what needs to be done? I assume this isn't GM releasing this info.
Yes, I had ran into this you a couple of times. I think in my case it was because I was tapping the starter button and not holding it in for a second. After I started pushing the starter button and holding it for a second or so the problem has not existed since. Hopefully that will be the problem.
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 771 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
