Well, just picked up a 1999 1500 4x4 Silverado with the 5.3 V8. I bought it from the original owner. Has 141k on the clock, pretty well taken care of, just needs some cleaning. Picked it up for 3k. Here we go!
First I started by pulling off the grill, tail light cages, and old side steps. Then I ripped off the side moldings, and used a rubber wheel on a drill to get the sticky tape off. Also took off the to bed cover and tossed that.
Awesome truck, good luck with the build.  Ive got an a 99 waiting for some work as well. I have to do a cab swap unfortunately due to being 2 boned where the box and cab meet.  Going to use a 00 body style to get that 4th door option.  It was the only complaint of the 99 new body style.
21 hours ago, garagerog said:
Welcome to the forum and what a transformation!  Lots of elbow grease I suspect!
Thanks! I'm only 34, but that hood kicked my butt! I've got a ton more in store!!!! I love to "tinker" with my vehicles, so this will be fun!
Picked up some new fender flares. I really don’t care to have fender flares at all. But there’s rust under the bed fenders. I’ll deal with that another time. Here’s a sneak peak of the old vs new fender. The new ones are OEM....
old...
Edited by Eggs2bacon
Edit
So the pictures make the truck look better than what it is. Here’s some pictures of the doors I’m working on. Running compound by Meguires does a good job and I prefer to hand compound.
My 2002 was starting to go bad with the black paint like yours but not as bad.  Only a matter of time before it took over the whole topside of the truck.
Looking great!   What are your plans for maintenance?  That is low mileage for a 99.  I take it you are going to do a full change out of fluids, or did the previous owner keep good records and did that as well?
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
