I have some Hot Wheels Redline cars from when I was little back in the early 60's.  Just sold my Rear Engine Dragster Don Prudhomme for $36 and an Army Police van for $51.
I remember my mother taking me to the local drug store and they had display cases for the matchbox cars. You would pick the one you wanted and it came in a small cardboard box with a picture of the car on the side.
Sent from my SM-N986U using Tapatalk
These are getting stupid expensive.
I have a redline 442 in my shop right now selling for $800.
It's not mint by any means either.
A lot of the beat up ones get $50+
Here's some of my stock.
Need any let me knowb4ec43218b13227735d9272a3141c50d.jpg9b5261b2ef17b4e7af4f807ee27ce49e.jpg33ad3eb7695af4dc95b05f4fe9b8c8e8.jpgd381e022d055c80d60802a3306a7d62e.jpgd587bf8b20b991e43cf82aa2e14fdffa.jpgaf8034c356b276e3d9fa95a9066cf96d.jpg2a8888f7f8e5d925bbba2be9e0ced6fc.jpg
Sent from my SM-G991U using Tapatalk
Where's your store located?
Buffalo MN 55313
Do I see a Blue Devil (C6 Corvette) on the far right of the 2nd shelf from the bottom in the case mounted on the wall?  And, is that a blue GTO right above it?
If the answers to these questions are yes, please tell me how much they are.  I have identical Maesto displays of those cars in the exact same colors.
Edited by Transient
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
