Looking at going from my 2019 5.3L silverado to the 6.6L gasser. I am getting rid of my truck to go crew cab either way just interested in the 6.6. Just looking for real world experience with it. Biggest thing I will be hauling is a 20' 10k dual axle open car trailer with a roughly 3600 lb vehichle on it for drag strip days. Will be a daily for my wife but she drives about 2 miles to work. So it will basically just be for my drag car on a trailer and side by side/quad/dirt bike hauler going up north here in Michigan. Relatively flat roads here.
might want to check the diesel vs gas forum lol.  Guess it depends on how many times you haul that thing and how far.  13k plus is a lot of weight.
Options may change the numbers some but for a crew cab gas is good for 14,500 and Diesel is 18k.
  • Sad 1
I should clarify the trailer is 10k axles idk actual weight of it would guess 2k. So 5600 total weight for car and trailer.
yeah with that either would be fine.
With that said I trailered a mustang 600 miles last fall with a half ton and didnt really know it was back there.  For that kind of weight and depending on you frequency  a bigger truck might be overkill
That short of a daily commute and that weight behind it is ideal for 6.6 gas truck.  it will do that very well.
I wouldn’t consider a modern diesel as a daily if it was that short of a commute.
The truck wouldn’t even reach operating temp, which creates a lot of DPF problems.
The mileage while towing will probably be similar to what the 1500 got towing but for day-to-day driving you will notice a big difference.  The tank on the 2500 is also much larger so expect the price at the pump to be a good bit more.  I went from an '18 1/2 ton Sierra to 1 '20 2500HD Crew and then a '21 2500HD.  I enjoy driving the larger truck more so I put up with the cost of the extra gas.
I would price out a 1/2 ton with the tow package vs the 2500 with the equipment you want and buy whichever is cheaper. A properly equipped 1/2 ton will tow that trailer without a problem too. If you need to load up the bed too while towing then obviously get the 2500. I would rather drive around a 1/2 ton but I need the payload of an HD.
the 6.6 gasser will be just fine. then you won't have to deal with the potential diesel issues. I should have bought the gasser. I only tow a few times a year and maybe 10K max
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
