Has anyone else noticed that the Silverado High Country DRL's are different than the other models? They are not as bright or as defined/sharp.
Just thought this was interesting...I'd think that the High Country would get something better if anything. But they seem inferior; at least in my opinion.
I have not noticed any difference in the DRL's but your headlamps and high beams are much brighter than the LED's in the LTZ.  I searched and the wiring is the same so if I keep my truck I will buy a set of High Country lamps.
WT, Custom, Custom TB
    Headlamps, halogen reflector with halogen Daytime Running Lamps
LT, RST, LT TB, LTZ
          Headlamps, LED reflector with LED signature Daytime Running Lamps
HC
          Headlamps, LED reflector (high intensity) with LED signature curtain Daytime Running Lamps
On RST -  Included and only available with (WGQ) Redline Edition.
On LT TB -  Included and only available with (WJP) Midnight Edition.
Yeah, the LED signature curtain Daytime Running Lamps have a wider illumination footprint and lens than the standard Silverado DRL.  I have no way to measure the relative output, i suspect its about the same amount of light, however over a larger area, so it may appear less bright. I like the HC DRL, it fits that area of the grill better.
On 5/12/2021 at 5:39 PM, redwngr said:
HC
Makes sense... I have an LT TB but have the Midnight Edition
