when i start the truck, radio volume comes on VERY loud.  In settings, i set the maximum startup volume to very low.  That works for a couple of starts, but then it resets itself to a loud position.  It doesn't matter what the volume is when i turn the truck off, it comes on VERY loud
i have the  opposite problem.  i set my volume where i like i and over night or the next time i start it, it goes back to zero or no volume, among other problems with "settings"..
talked to our salesman and the service manager.  They never heard of the problem.  A friend with a 2021 Silverado is having same problem.  He's taking if in for service tomorrow.  I will tell you what he finds out.
I have had a problem where my radio starts up crazy loud for a couple seconds then "sets" itself to MY Profile settings. After researching in here, there is sometimes a delay from startup to when your profile syncs and it uses your settings. During that delay it will be at whatever the settings are when there is no profile selected. I am trying to delete my profile now and use the "no profile" now with the sound settings at my preferred levels and see if that helps. My thought is that if you set the NO Profile settings to what you want, then there re sign in with your profile, there shouldn't be any issues anymore. IF your the only one that really drives your truck then really no profile is needed.
I don't think I have a profile set up.   Or if it's even an option on my truck?  How do you even check for a profile?
When you hit the home button for your display there should be an icon that has either "Profile" or Maybe "Users" Should look like a person of some sort. Usually if you use the same key fob it'll sign you in automatically since you're using that key.
Hmm maybe it's not on the LT's. I haven't noticed it anyway. I'll have to check.  Thanks.
Edited by THE YETI
No 'users' or 'profile' on my home screen but I remote started it then got in a couple mins later when I turned it on and went to drive away. It was quiet.  The way I had tried to set it before.  I'll have to check again next time just starting normally and see if it still stays how it was set before.
Yep!  Profiles are more of a pain in the ass than they're worth.  Since I'm basically the only one driving it, I nixxed that whole deal
Damn. Mine seemed to be working. Then started it up and bam loud AF again. Then was good again next time. It seems to have a mind of its own. I always had the same key fob in my pocket each time too.  I'll get this figured out eventually I guess. Otherwise I'll have to mention it when I go for my first oil change.  (On a side note. Do these things still come with first 2 years oil changes for free?  Otherwise I'll do it myself)
Yes. Call the dealer. There is a patch for the 2021. Took about 30 minutes. I did not leave it all day. Seems to be holding altho it is a patch.  1-2 months for the software fix according to my dealer.
Damn.  I ain't got time for the dealer. But it is what it is I guess.  Suppose a visit there will be in my future sooner or later then.  Was hoping to wait til the first oil change(if they are still complimentary for the first few) but it's kind of annoying and the neighbor probly doesn't appreciate it at 5am every morning either.
I logged out of my profile and returned to guest mode.  I went into settings/sounds and turned the start up volume nearly all the way down.  I logged back into my profile and now now no more LOUD start up!
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
