I have an affinity for natural wood surfaces and I am strongly perturbed by the digital grain on the interior door trim pieces.  I am wanting to replace them with the natural wood pieces found on some of the upper trims (Chevrolet and GMC) but I can't find any pictures to go with the names:
Geo Jigsaw
Anteak
Savannah Mosaic
Arenite
Nitiride
Hewn Cypress
I assume the fake wood print in my LT is the Geo Jigsaw, which I really don't prefer, but I cant find any images on google to match up to the other descriptors.  I would prefer not to make a trip down to the dealership to scope out trucks and VINs, especially considering inventory is so low here and I'm more likely to see 15 WT's than a single Elevation or High Country.
Does anybody have any clue on where I can find a list of the above descriptors with corresponding images?
My 21 Denali says it's real wood open-pore ash wood.
I don't believe the names you listed are all wood trim. I am under the impression there is the real wood trim and the synthetic wood looking trim. The rest are different, as in carbon fiber looking and so on.
  • Thanks 1
You are correct, they are all different types of wood and composites.  I was posting all of them hoping that someone could pick out the real wood ones :)
Thanks for the lead on your Denali, I'll check out Open Poor Ash Wood and see what I can find.
I don't think its actual wood, even on the Denali. I read that also and assumed it was, but if you remove those accent pieces...they are plastic. if it is real wood it must be a paper thin veneer bonded to a plastic piece, but I looked very closely inspecting for a seam that would indicate as such, I could not find anything. as far as I can tell those pieces are plastic fake wood.
I actually looked into whether I could get a real wood veneer and apply it over top of the plastic piece, but didn't get too far with the research. I wasn't sure if a real wood veneer would be able to curve sharp enough without breaking, although I think it may be possible.
  • 3 years later...
I got the inside of the door wet and now wooden pieces are swelling up? If it’s plastic it’s acting like wood!
  • 1 month later...
So how did you go about making it go away? I just got the panel wet and the wood is all bubbly…
The topographical thing is only on Denali Ultimate.
'Regular' Denali does not have that.
(Denali Ultimate is now a trim level, rather than an option added to a Denali)
I just left the windows down in 90 degree heat in Florida and it dried up, still had some small bumps, oiled with old English for light wood.
