Hello Folks!!
I wanted to reach out to those who have the 2021 Silverado 1500 Crew Cab with seat covers.  What brand did you choose and what website did you order them from.  I am looking all over and having a hard time choosing.  My first look was Amazon but you know how that goes and the reviews for what looks like may fit are never the information you really need of how it fits.  Please provide any pics or links to what you bought if possible. Thanks so much!
Ive gotten all my seat covers through cabelas. But my price point may be lower than yours. I only use them to protect the seats when my buddies and I go on hunting trips. Otherwise I dont use them. They do seem to have all levels there and the last ones I bought are like neoprene and pretty nice.
I have been looking at those. From all the reviews I saw, It was not a for sure mind made up.  Would you have the link from Amazon of your purchase so I can get those exact ones?  Thanks!
I ordered a complete set (front & rear seats) from this company.    https://headwatersseatcovers.com/
I haven't received them yet as they are a few months out on work.
They were recommended to me by a friend here in MT that is a contractor with a few trucks. He swears by them.
Couple questions for those who have covers.  I have leather seats and appreciate the ability to slide into my seat rather easy (as opposed to cloth seats).  Do any seat covers come close to having that ability?  I don’t want to adjust myself or the seat covers every time I get in the truck.  Also, one thing I can’t stand with cloth seats is getting a static shock when I get out of the truck.  Do any of you notice this with the seat covers?
I do like the idea of the CalTrend as they are made in the USA.
I use Clazzio seat covers, they are made out of pvc they do offer leather too. They don't move at all. Most people think I have factory leather. They go over the top of my cloth seats. Have been great so far. I slide my 6'2" 270 self out of the truck all the time no signs of wear and no movement of covers has been noticed.
  • Thanks 1
  • 1 year later...
I know this post is old, but I am hoping you guys get the notifications when someone replies.
For the folks who have the Aierxuan seat covers, any tips on fitting the "discs" through the seat gap so they stay in tight?
  • 1 month later...
On 9/15/2021 at 12:41 PM, J Allensworth said:
Hello Folks!!
I have the Aierxuan seat covers (see my post in mods) and I love them. Though I’m a double cab, the seat bottoms would cover a crew cab. I owned a ‘21 LT Trail Boss 6.2 before this one. I got them from Amazon, and they’re waterproof. Cost me $200.
    • Of course actually engaging four wheel drive is step one or even daring to use a ramp like that with a two wheel drive and getting into a mess because of it. As to 4 low, these last few years if its a GM half ton it may not even have low range. A lot of the newer pickups have a lot lower first gear in an automatic transmission then they once did as it was common at one time for a gas engine truck or even the older diesels to just sit there and bog the engine due to the torque converter stall point and not enough torque was generated on reasonable traction to even spin a tire or get out of its own way up a steep grade and 4 low HAD to be used to get enough power to four tires to get them turning. These days traction control systems may hinder a vehicle in a situation like that although that means a tire or tires are spinning so in some ways the traction control can reduce wild spinning and anyone can correct me on that but I think some vehicles cut traction control off in low range ?.    By the sounds of it and you may have the proper equipment but if your responsible for helping vehicles out if they are not able to get out under their own power, I would say to be using a nylon tow rope or have one available so that one is able to give a bit of a run to help sling shot them some initial momentum as most tow straps are made out of polypropylene and impart way too much shock load if used to jerk a stuck vehicle into motion but are totally fine to use if going more from almost a dead pull with the tow vehicle and they are a lot less expensive to replace if damaged. That and some soft shackles to hook onto closed loop tow hooks on the truck your pulling as well as you having the proper shackle insert in your truck so there are no bad accidents with metal clevises joining things together or chain on the end of a tow rope or tow balls being hooked onto etc flying and causing damage or worse if it lets go. Its always a challenge pulling people because some are clueless and will over run the tow rope or strap and drive over it or that risk of ramming into the back of the tow vehicle so usually a few instructions are needed to clue in the driver of the stuck truck. Yeah ... have fun out there 😉
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
