On 12/11/2021 at 12:47 PM, BlaineBug said:
Correct me if I am wrong but here are 4 lines I see running to my radiator and the condenser up front. 2019 Yukon with active aero shutters in the grille.  All 4 lines are the same quick disconnect style with the clip and plastic retainer.  Are all transmission related?  I didn't think the A/C lines used quick disconnects like these, but I'm also not sure where the engine oil cooler goes.  As far as I am aware there was an engine oil cooler.  I do not have a factory towing package, as in, no integrated trailer brake controller in the dashboard and no 2-speed transfer case (2wd, auto, 4-hi only.)
6 speed or 10 speed?
8 minutes ago, BlaineBug said:
Strange.  What I typed myself is straight from the build sheet.
That's a copy past of mine.
6 speed myself as well.
Edited by 14burrito
17 minutes ago, BlaineBug said:
6 speed.
So the two big lines in your picture, those are engine oil cooler.  The two smaller ones (one on the driver one on the passenger) are for the transmission.
2019 Yukon 6 speed its trans to the aux cooler only, no connection to the radiator.  See pic below:
Edited by newdude
3 minutes ago, BlaineBug said:
Maybe it's a difference between Chevrolet/GMC?
No difference in RPO codes for 95% of the stuff between the brands.
Yup 👍
Makes sense, I possibly recall this mentioned here before.  So the engine oil cooler is in the radiator?  I would assume engine oil would be much hotter than ~210 degree operating temperature of coolant so that makes sense, "cooling" it to somewhere around ~210 degrees from something that would normally be much higher.
Disregard my original comment. Weird this forum doesn't allow posts to be deleted.
Edited by 14burrito
I see GM-Trucks email notifications suddenly began working today again so I got to see your deleted comment about how the engine oil is cooled by airflow passing through the radiator.  While that is true the temperature of the radiator itself also cools or increases the temperature.  Since I believe the engine oil would be much warmer than ~210 degrees I'd have to say that the coolant (and airflow of course) are cooling the engine oil together.  Subsequently some of that heat is also making its way from the engine oil to the engine coolant too.
Yes.  Engine oil goes to the radiator.  If you ever get the chance to watch live data, engine oil temp typically runs within 10 degrees of coolant temp at operating temperature.  Towing would raise it I'm sure a bit more, probably 220-230F.  Used to watch it in my brother's 2014 Camaro, oil was consistently 205-220 degrees, just above coolant temp at 195F.
Edited by newdude
Live feed about 2 hours in on a 60 F day. 6th gear. 3.23 final drive. 31" H/T tire.
This is an average day for Pepper.
This truck has both oil and trans coolers in the radiator.
Drivers side oil, passenger side transmission.
(opposite the V8 models)
170 F water thermostat.
No secondary trans cooler in A/C condenser.
Pill flip in transmission.
More Cold weather data.....
Yesterday went to Daughter's about 15 miles down the interstate.
Temp was -14F
20 minutes warm up , trans was 70°F out the driveway and warmed to 90° on the streets leading to the interstate.
Got on interstate hit 70mph. Watched it drop to 84° and stayed there until the exit.
    • I was the GM of a Lincoln Mercury dealership back in the 80's. The service lot was always full with "broken" ones. Plenty of transmissions, power windows and a/c repairs. The only one I'd consider owning would be the Marauder at this point and it certainly wouldn't be a daily driver.  My 2025 GMC Sierra 1500 Denali Ultimate is my "Lincoln Town Car" in my retirement. I want all the "stuff". Big infotainment screens, one touch power windows, Supercruise (I won't buy another vehicle without it), hands free pretty much everything. I'm going to swap my current truck for a 2027 Yukon Denali Ultimate so I can have the air suspension and surround vision recording along with all the other "stuff".
    • Yep mine is on backorder also.
    • The Denali Ultimate's grille is tinted, but the "regular' Denali has a bright chrome grille like the current models.
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
