2010 Silverado with 140,000. I switched from Valvoline High Mileage synthetic blend to Valvoline High Mileage full synthetic both 5w-30 and from a Valvoline VO88 oil filter to a Wix Xp. Why did my oil pressure go from 41-42 psi at cold idle to around 28 at cold idle after switching?
Are you sure this IS the correct filter for your application, sure the filter is on tightly? Did you put the oil pan drain plug back in and properly (read not over tighten but to the spec.?) tighten it? Did you check the oil lever after filling (this ensures the oil is in the pan and not on the ground) but prior to engine start?
Stranger things have happened!
Filter will NOT affect op. most of the oil bypasses the filter, the things that affect op are oil viscosity, oil pressure relief valve and bearing clearances. also restricted pickup screen. try changing back to the oil you were using and see what happens, maybe the oil was labeled wrong
Normal event. Less resistance to flow.
If your ambient temps are colder than the last time you observed cold start oil pressure you are also seeing pour point depressants in action keeping oil at 5W for crank and start pumpability.
The chemistry of the valvo blend vs full syn are dramatic in colder ambient temp ops.
Regardless it’s not a bad thing.
Your normal operating temp oil pressure may be lower too. Also not a bad thing unless below normal pressure for the oil pump.
On 11/12/2021 at 12:07 PM, Black02Silverado said:
Just curious as to what is the part number of the Wix oil filter you installed?
57060xp
In my of 50 years as an ASE certified tech i have seen a fare share of bad oil filters and if the oil is the same viscosity regardless of mineral or synthetic oil the oil will not change the pressure its always the oil filter. Under normal operation the oil filter passes 100% of the oil through it but when the filter becomes plugged the bypass allow oil by the filter lowering the oil pressure.  Change the filter its easy and cheap.
i disagree, the oil pump makes enuff pressure to explode a filter, if the bypass valve didnt work you would have hundreds of lbs of op. high performance pumps have changable relief valve springs to adjust desired pressure. I have also been a tech for almost 50 years and built my own race engines
Oil pressure is directly related to resistance to oil flow.  Because of the lower resistance to flow that synthetics offer, the oil pressure will generally be reduced as well.  Lower resistance to flow also means less friction and potentially better power or efficiency.
    • Anyone have any info about backorder time? It's classic 4th of July hot here in ohio.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
