Good morning folks!  Got a call from my service advisor at my local GMC dealer that there was an infotainment system update available to download.  I asked him if it could be completed OTA (over-the-air) as I hadn't received any automatic updates (nor manually either).  He said that it appeared, due to the size of the update, that it would require the vehicle to be brought in for the service.  He admitted he could be wrong about getting it OTA, but this was his experience with it (see below).  Brought the truck in and was heading home 45 minutes later.  No issues with the update...so far!  This is a long post!
I subscribe to a website called RepairProcedures.com and was able to look up the software update to see what was...well...updated.  Here's what I learned:
  • This update is for vehicles equipped with infotainment systems ROP codes IOS, IOU and/or IOT.
  • The reason for the update was to fix software-related anomalies.
  • A new radio software update, version V158, was released to service for vehicles equipped with Infotainment system RPO IOS, IOU or IOT. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases (i.e. V152, V155, etc.). This update can occur remotely through in-vehicle prompts from the radio display. However, some customers may decline the vehicle update, or the update may be unsuccessful. Along with the vehicles mentioned above, vehicles in unconnected markets, and fleet customers may need the dealer to reprogram the radio with the new software package.
V158 Most Notable Improvements and Fixes Include:
Bluetooth
  • A blank or black screen may occur when making a slight adjustment to volume knob
Camera
  • Automatic Park Assist (APA) may not switch to the 360-degree camera view at times
  • APA may not launch.
  • Note
    It is normal, design-intent behavior for APA to not launch while 360-degree view is active. This fix will not change that.
Energy
  • Improves graph format in Energy app
  • After pressing the Stop Charging and Unlock button the screen may not display a message that charging has stopped and that vehicle can be unplugged
  • Charge completion time may display in an incorrect color
  • If a user attempts to select Charging Options while the vehicle is being driven, it does not display feature unavailable while driving
  • After setting “Stop Energy At:” the Rate Schedule Type may not change
HMI
  • Non-responsive touch condition that self-recovers after 3 minutes may occur after installing any app
  • While downloading an app the characters in notification that indicate time remaining may be incomplete, the lower portion is missing
  • While using wireless charging and after ending a phone call CarPlay will show the phone is still charging but the Home screen charging status may not match
  • Bluetooth phone signal and battery icons may appear and disappear intermittently when Performance Data Recorder (PDR) is active
IPC Interface
  • A portion of the Press Handset overlay message may be missing in the IPC
  • After merging two phone calls, the IPC may display a blank overlay box
Navigation
  • When Head Up Display (HUD) transitions from Next Maneuver overlay to Lane Assist the display may flicker
  • After changing Location Services from Off to On, the Traffic Flow feature may not become active
  • The navigation interface may change to 2D and be inconsistent with Porch view display after sliding on the Destination card
  • A speed camera icon may intermittently disappear and reappear on the map
  • Improve navigation map data SD card VIN binding process
  • Improve, but not yet eliminate, an SD card removed message that may occur only on startup when using a customer’s User Profile
  • The Speed Bump Alert may disappear at the beginning of route guidance on certain destinations
  • Voice Recognition button may appear in regions that are not supporting the voice recognition feature
  • Charging station POIs may be displayed on the opposite side of a roadway
  • SD Card error message displayed with 0x8 error code
  • Predictive navigation estimated time of arrival (ETA) appears on radio, but may display dashes on instrument cluster
  • Navigation route may not start from Main screen if user selected “xx minutes to Home” by steering wheel controls in the clusters Navigation Menu screen
  • Alerts for Charge Vehicle Soon and Charge Vehicle Now may not appear in the radios Navigation app while the vehicle is being driven but do appear in the cluster, and Charge Vehicle Now does appear in radio if vehicle is stopped
  • (Non-GMNA) When GPS signal is blocked (example: parking structure) the dead reckoning may not go active causing vehicle to have to reacquire GPS location once leaving the structure or area that blocked GPS signals
Settings
  • Door Lock/Unlock customization settings for All Doors or Driver Door Only may not be retained
  • The Collision/Detection Systems customization settings may be missing some options after changing languages
  • If in the Settings app when ignition is cycled off then on, the Settings page may be blank
  • While scrolling in the Climate and Air Quality interface settings the display may flash
System
  • After using the Infotainment Control Switch in the center console to change the station in the Tune screen, any input into the radio may change the station again. Example: Pressing the Radio button on the control switch to return to the Audio page or shifting to Reverse to pull up the rearview camera could cause the station to change again
  • When attempting to adjust Lumbar position a message that “Massage Seats Unavailable” may appear for one to two minutes after startup. The memory seat function will still recall Lumbar settings
  • At startup, the display may freeze on the myBrand splash animation screen. A radio sleep cycle recovers this condition
  • Improve ethernet DTC diagnostic algorithms for U1008, U18B4, and U0078
Trailering
  • When launching Trailer app, some trailer profiles may cause the display to go blank then return to Home screen
I don't know if any of you are affected by some, or all, of these "fixes", but it certainly cleared up a couple of issues I was having with the truck.
Cheers!
Tim
Good to know..Thank you.  I kept expecting to read the portion where you said it screwed up yout truck..lol
  • Haha 1
While in for other issues I complained about my radio function and they did an update about 2 weeks ago. Prior to the update my radio would turn on but be at zero volume. It would also automatically connect to my phone and auto-play whatever book or podcast I may have been listening to. It wasn't earth-shattering but it was annoying. Fixed that.
Would it be possible to add heated/cooled seats in my 2014 if I were able to come upon a wrecked vehicle for the parts? I have heard the computer in my truck wouldn’t let it work, but if anybody knew for sure I thought you might. And if I need a harness to make that work.
Does anyone know of a way to watch videos from your phone on the screen. On my 2017 I was able to have the radio module unlocked to be able to watch videos and use the nav while driving. Can this be done on the 2020. By the way mine successfully updated over the air
Bluetooth
Camera
  • Note
Energy
HMI
IPC Interface
Navigation
Settings
System
Trailering
Cheers!
Tim
I see you are a fellow "bubblehead"!
As a matter of fact I am!  Boomer's...to be exact.  You?
SSN 668, SSBN 733 (G), SSN 714, SIMA 67HS.
Fellow brother of the 'phin!
Nice!  I was on SSBN 620(B), 641(B), 734(G).
I have an appt to go in and hopefully they know it is an update and can update it manually.  Would be nice if GM would allow up to update it our selves...
Got an update that failed and I have not display at all update failed...Only displays a command window.
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
