On 1/16/2022 at 2:53 PM, L8T said:
This will never happen. The Allison is heavy internally and will rob too much hp to make it viable. Not to mention awful fuel economy. Hence why they dropped the 8.1/ally combo years ago.
Love my 2001 8.1L with 4.10 gears.  After 21 years, I would not change my purchase for a diesel just because it gets bad gas mileage.  Every winter running 87 octane, I get 10-11 mpg mixed driving.  Every summer running 87 octane, I get 12 mpg.  If I run midgrade gas, I pick up 1 mpg and a more enthusiastic engine response.  It has had the common minor repairs but the engine behaves exactly the same way I drove it off of the lot.  I have 165,000 and it starts every morning, regardless of the conditions.  I tow a 13,000 lb gooseneck horse trailer when fully loaded.  The truck handles it nicely as long I keep putting gas into the tank.  When I tow it averages about 8-10 depending on the elevation gain of whatever pass I am traveling over.  I am not the fastest driver since I want to give my horses a nice ride so the fact that I can't go 80 mph over a large pass is a non factor.  I am starting to look at a replacement and wish GM would do another big block. The Allison has been worth every penny.  I would look no further if GM paired any gas engine with the Allison.
I dont believe this was the case.  The big block got the same mileage with a 4l80e, 4 speed behind it, which is what the 8.1 suburbans came equiped with.  My 01 2500HD has the 8.1/allison combo and now has 180k-ish miles on it and gets 10-12.  I believe the motor was rated 345 horsepower.  The new 6.6 small block is 410 horse, i cant see it having any problem with the 10/1000 allison
Edited by vucelick
100% this was the case. 4 speed was awful for mileage due to its gearing not its weight. 10-12mpg (at best) empty was not an acceptable number at that time for majority of customers and still isn’t today. And when the 6.0 came out and got better fuel mileage with more hp/tq it was a no brainer to ditch the combo-and the engine altogether.
There’s always a few guys with lady boners for that combo out there but the fact remains it was an awful combo. The current 6L90E has a lighter converter than any ever used in an Allison, planetary hubs and gears are all lighter, the entire assembly overall is lighter. It works well as did it’s predecessor. No reason for a trans that can easily hold over 1000 ftlbs tq to be paired with a gas engine with much less. Not to mention a totally different tq curve and rpm range.
Again, i do not believe that is true.  The 6.0 did not get significantly better mileage than the 8.1, nor did it have more torque.
Edited by vucelick
I agree with that. With the fuel mileage I get with my 6.0, I might as well be at 8.1 liters. Although cruising down the highway at 70 I can squeeze out 15-16 mpgs. City and towing forget about it.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
