Anyone know, or want to best guess this tire size?
It looks leveled, and looks like up-sized tires.
not sure if there are wheel spacers.
I would like this exact setup.
I just can’t remember where I found this photo.
I have the same truck…currently running Icon 3 1/2 level (1 1/2” added to AT4) with UCA’s and rear Icon shocks…with 1 1/4” wheel spacers with stock 20 tires/wheels.
Thanks!!!
Those are Nitto Ridge Grapplers. My guess on size is something around a 34in tire.
I thought the larger factory size was already basically a 33in tire.
Yeah, they seem too wide for stock tires…20’s or 18’s.
I was hoping this was someone’s truck here who could tell me. 😉
And they don’t seem stock, because they seem to be Nitto’s, and probably not KO’s…
even though BFG’s AT’s are what I want.
The truck in the photo appears to have a 1 upsize tire.  Wish I knew what it was.
The picture is from a dealer lot so very small chance anyone here owns it lol.
I'd pick your tire size sooner rather than later, Michelin Tires are going up in price again after the 1st of the year. Michelin owns BFG so expect them to rise as well, this will be the 4th price hike in 7 months. Some tires have gone up 25% already since this all started.
NerdStrong,
I think it’s closer to a 295/60R20, too (your 1st guess). 😉
I think 285/65R20 (34.5”) would require some serious trimming.
Edited by Gmoeller
10 hours ago, Gmoeller said:
NerdStrong,
I got a buddy he runs the 285/65/R20 NRG on his 20’ AT4 stock suspension, no rub no trimming.
I’m in the process of order the same ones, but I have a leveling kit and UCAs
I’m seeing guys putting 285/65/20’s on here too.  For the life of me, I just can’t see how they don’t have to cut or trim.
You have a leveling kit for an AT4, or leveling kit for non AT4?
Please post how your tire fitment goes on your truck. 🙏🏼
I think a lot of times when folks say no cutting or trimming they mean to the grocery store and back, not on switchbacks covered with boulders. Granted, that's not what these trucks are for but worth the consideration if it's gonna come out of your pocket with expectations beyond appearance.
As soon as my tires arrive and mounted I will shoot pics. I’ve spent what I feel is to much time on searching for tires lol. Same with the leveling kit (meant for my AT4), that’s why I didn’t go with RC leveling kits but the Readylift SST with the UCAs.
Cool!!
I know what you mean.  I know what I want it to look like, but I don’t know which setup is the setup to get that perfect look (for me). The challenge is you have one shot at getting the look right…cuz you can’t return them. 🙂
Keep me posted. 👍🏼
And good move on the UCAs. 😉
I vote 295/60r20, they look wider than a 275 or 285.
Im running 35x12.5r20s on 20x10 wheels on my 21 TB with a 1.5" spacer. I had to do some modifications in the fender but it looks very clean.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
