So I haven't posted on here in about 2 years.
The first and only real issue I had with my truck came weeks after getting the truck in 2019. The lock control solenode would not click and I could not get the truck out of park...this resulted in a replaced Gear Shift Assembly. Now there seems to be a very dangerous flaw in the Auto-Stop/Start feature.
When I come to a stop in traffic / at a red light, the truck obviously will turn off. When I let off the brake, the truck will start up and slowly roll until I start to press the gas. If I start to push in the gas pedal almost half an inch to and inch with my foot off the brake after it starts back up, the vehicle immediately throws me back into my seat and rapidly accelerates. I immediately have to slam on the brakes to stop it from hitting people in front of me. This has happened probably 3-5 times in the last 3 weeks.
I have 9 months left on the lease (12k/36 months) and 19k Miles on the truck. I'm not sure if anyone has experienced this issue.
I would turn off the auto stop/start until you get things sorted out. Good luck!
Just crossed 22k miles today on my 2020.  No issue like this so far.
Edit:  Looking at the 22,500 mile service interval via the MyChevrolet app I noticed there is a requirement to check the gas peddle for operation and replace if needed.  Might be worth taking it to the dealer to have the gas peddle inspected.
Edited by Transient
2 hours ago, Rob Mugs said:
Never had this happen.  Are you a 2 foot driver?
Nope.
I'll look into that. Thanks.
Huh, yeah its like your pre-loading the converter... You should try bringing it up to around 2300; make sure no one is in front of you 😬
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
